Descendent kit installed and not firing up
Hey turbo guys i installed my descendant kit today. I pulled ign fuse crank it couple time to get fuel in injectors. Then put ign fuse back fire it up nothing car didnt start up at all..please help!
Hoping you changed your spark plugs to NGK iridium one step colder with proper gap what is the car doing? More details.. Check all connections to FIC? All vacuum lines ran?
I didn't change spark plug . I still have factory plugs, everything hook up right. fic harness is right and ran harness power wire to ciggerite lighter. remove efi1 fuse crank it for little bit for fuel to be in line. replace efi1 back crank it and it just won't fire up.
Check all fuses. That'd be the first place I'd check. I'm having a similar issue. I popped a couple of fuses, AM1 in particular. Have to go buy a replacement today so I'm hoping that was my issue.
I'm just merely suggesting to check it. My AM1 fuse is blown. All my dash lights are on as well. My car starts though. Not too sure. I'm gonna work on it more tonight. I'm sure another fuse is blown for me or it could also be my alarm system that is somehow interfering with something. My radio, door locks and windows aren't working for me. Having my cousin, who's a Toyota tech come by and help me out too.
Yeah , thanks. Hope so too. Have no clue in the cig lighter question. Not sure where they installed it to get 12v power. Yes, car still starts up and fires up just fine. I had blown the ECTS fuse as well, but fixed that. Has to be another fuse in my case. Just have to find which one.
I'm not familiar with the AEM FIC system for the TC2 and I might not quite understand what your saying about connecting the harness to a power source... But doesn't the AEM FiC get powered through the stock ECU using the PNP harness?
