Whirring sound any ideas?
Hey everyone!
So I have a manual 06 TC, with about 83k miles on it. Yesterday I fired her up like normal, but I immediately hear a sound which I can best describe as a "whirring" sound. It occurs in neutral OR in gear, and gets louder as I rev the engine. I hear it up until about 2k RPMs, but don't hear it much beyond that, possibly due to engine noise drowning out the whirring.
I learned our water pumps commonly need replacing. Sure enough, there was pink residue around the water pump, so I replace that. Fire her up again, and the whirring is still there! Then I change the serpentine belt, and the whirring is still there.
The funny thing is, I had someone spray wd-40 on the water pump pully while it's on, and the sound goes away briefly, but comes back seconds after. I'm at a loss and will take her in this week. Does anyone have any ideas as to what the sound might be? Sorry for the long post to a simple question: WTF is that noise?
(I will try to add a video example of the sound soon just wanted to ask the community asap)
If u sprayed wd-40 on the pump and the noise went away its prolly the water pump. Take a long screwdriver and place it on the waterpump while its running and put it to your ear. If its the water pump you'll hear the noise through the screwdriver
yeah it sounds like the bearing on the shaft of the water pump has begin to die. The pink crusty stuff is coolant leaking from the weep hole of the pump. That's a sign it's bypassing and it's dying. It's time for you to replace the water pump. Do this soon the longer you wait the more risk to overheating the engine and if you do that, the head will separate from the block. There are many 2az-fe engine owners (our engine plus camry, rav4, etc) that know about this issue. The key is to NOT let the car overheat.. get that water pump fixed soon!
I am getting a high humm from the serpentine belt area and I know that it is more than likely a bearing going out in the water pump, alternator or one of the other pulleys. Scoped it and it sounds like the alternator but I am worried I will drop the two fifty on the alternator and it will end up being the water pump lmao how can you be sure what pump/bearing is going bad?
EDIT: Just found the pulley for the alternator from Toyota, here's the part number 27411-28060, about $23
27310B BEARING(FOR ALTERNATOR DRIVE END FRAME)
90099-10142 (05/2004 - 10/2006)
90099-10223 (12/2006 - )
The dates you see are tc production dates, this is when your car was manufactured, on the drivers side door that label tells you the production date.
...and hey you're welcome!
Thank you! ended up being the alternator. The bering inside was going out. Finally found an autozone that had a tester that actually connected a belt to the alternator and put a load on the pulley. It made the same sound.
Raiders757
Apr 14, 2015 10:26 PM
cid_mcdp
Jan 5, 2015 02:45 PM
