2.5" vs. 3" exhaust NA questions
Old Apr 19, 2005 | 12:59 AM
PoizentC's Avatar
Default 2.5" vs. 3" exhaust NA questions
Just got a 3"inlet/outlet magnaflow muffler. I'm getting custom piping done this weekend. I am trying to decide whether to go 2.5" or 3" all the way through. I am almost 100% sure I will be going turbo within the next few months. My question is should I go 2.5" now then redo the exhaust to 3" when I am turbo or just go 3" now? Will there be a significant power loss with lack of backpressure due to the bigger piping on a NA car? And will it be rediculously loud? Thanks for all the input.
Old Apr 19, 2005 | 01:09 AM
EMU's Avatar
EMU
i say 2.25 or 2.5 for n/a...really losing backpresesure with 3". get all mandrel bent piping. piping should be redone to 3" after you got the turbo.
Old Apr 19, 2005 | 02:05 AM
PoizentC's Avatar
yup that's what I was planning on doing..thanks for confirming my thoughts
Old Apr 19, 2005 | 02:53 AM
DouBLeJ16's Avatar
Are you going to cut the exhaust after the s-pipe and weld on the custom pipe after that?
Old Apr 19, 2005 | 03:12 AM
PoizentC's Avatar
my custom piping will include redoing the s-pipe
Old Apr 19, 2005 | 03:54 AM
Joe_Dezod's Avatar
Yeah stay away from anything larger than 2.5" until the turbo is installed. At least the 2.5 is still ok for turbo, 3" is just to get the most out of it. 3" is UBER loud at high rpms on an NA car, so I'd stay clear of it.
Good luck with your prject though.
Old Apr 19, 2005 | 04:57 AM
taek's Avatar
i myself is getting custom exhaust done soon too. you guys answered my questions too. good stuf
Old Apr 19, 2005 | 07:07 AM
DouBLeJ16's Avatar
So you aren't worried about the CEL coming on?
I'm planning on cutting the exhaust after the s-pipe (right after where it bolts up to the midpipe). That way when a aftermarket s-pipe is finally out I can just bolt it to the mid pipe.
Old Apr 19, 2005 | 08:40 AM
GSRacer2102's Avatar
2.25 is best for NA cars like everyone else said.
Old Apr 19, 2005 | 02:00 PM
skinny's Avatar
it wouldn't hurt to have 2.5 on either turbo or on na, unless your going to boost more than 6 to 8 psi. anything more, go for 3 if your boosting 12-20 psi
Old Apr 19, 2005 | 02:39 PM
PoizentC's Avatar
I thought the car would only throw a CEL if you are running no cat. And isn't the s-pipe going to be the same thing whether I get one made or buy one from an aftermarket company assuming they are both mandrel bent?
Old Apr 19, 2005 | 04:31 PM
CELL's Avatar
whats an s-pipe?
Old Apr 19, 2005 | 05:50 PM
PoizentC's Avatar
Originally Posted by CELL
whats an s-pipe?
https://www.scionlife.com/forums/vie...diagram#676930
view 4th post from top
Old Apr 19, 2005 | 08:05 PM
jlaznlover's Avatar
personally, i think you should wait until you get the turbo installed, then do the 3" exhaust. since you already know that you want a 3" exhaust, why not just wait a little bit longer? save the money that you would of spent on the 2.5" exhaust and put it towards your turbo needs.
Old Apr 20, 2005 | 01:42 AM
skinny's Avatar
still depends on the boost your doing, if you only doing 6-8 psi, then go ahead with the 2.5
Old Apr 20, 2005 | 03:07 AM
Mx6GT91's Avatar
2.5in only. Do not do 2.25in, stock is 2.25in but its crush bent. Since your getting it custom done Im sure its going to be crush bent pipes. Shouldnt hurt the flow too much but it will hurt flow.
3in is pretty big for N/A but it wont hurt back pressure much on these cars. Its a very big motor and dynos have proven good horsepower and torque gain running open header.
I have a crush bent 3in turbo-back on my Mx6. Made a huge difference even though its crush bent.
2.4L plus a turbo even on low boost needs 3in.
Old Apr 20, 2005 | 11:35 AM
Mediocre_Generica's Avatar
Stock is not crush bent. Stock is 2.25 mandral bent.
Backpressure being good is bull____. Look at the dyno readings for an upgraded header & exhaust on this same forum. Backpressure was reduced significantly, and both HP and TQ still rose alot.
Old Apr 20, 2005 | 06:39 PM
Speedpunk's Avatar
While it can and will increase peak HP & TQ numbers, the more important thing to look at is how well it is distribute, especially in NA cars. If I get and extra 15 hp from 5000 rpm's to redline, but drop 10 from idle to 5000, you can keep those mods. I had a 3" on my 1.8T GTI, and even with a turbo and hi-flow cat in the way, it was still LOUD. Just rock what you got until you install the turbo.
Old Apr 22, 2005 | 08:18 PM
vspec04's Avatar
This man knows what he is talking about, for best results go 2.5-3, if you plan on going turbo then 3 for sure, It will not hurt velocity, you have a 2.4l engine, you'll be fine.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
viciouzgamer
Feb 18, 2015 03:26 PM
Jumphiggggg
Feb 13, 2015 04:05 PM
TotalChaos
13
Feb 4, 2015 10:24 PM
