Suspension Question
Old Feb 21, 2004 | 01:14 PM
BigBadWolf's Avatar
Default Suspension Question
Last time when i ask this, i open my mouth and switch foot.. :oops:
Let hope i get it right this time
On a xA..... What should i expect from Coilover. (Tein for Example) Ride comfort wise?
As compare to just (TRD)spring. With a Coilover, does this mean i don't need the spring?
Old Feb 21, 2004 | 03:59 PM
DJ_X_Trodinaire's Avatar
Default Re: Suspension Question
TRD Spring = just springs
Coilovers = springs and shock/strut combo = adjustable ride height, more sporty handling
Old Feb 21, 2004 | 08:59 PM
jackmott's Avatar
totally depends on the spring rates of the springs on the coilovers, and the shock valving of the coilovers.
the TRD springs are not very stiff, the ride is still quite comfortable
Old Feb 22, 2004 | 07:20 AM
Guest
Guest
Posts: n/a
Tein will be a stiff ride so, if you are looking for a comfortable ride and still be lowered. I suggest eibach springs. :D
Old Feb 24, 2004 | 03:46 PM
BigBadWolf's Avatar
Default Spring?
With a coil over, Does this meant it replace both the spring and damper?
Old Feb 24, 2004 | 04:11 PM
jackmott's Avatar
Default Re: Spring?
yes.
a coilover is usually a shock/spring combo, along with a threaded spring perch alloying for ride height adjustability, and sometimes the shocks are adjustable.
you could also get TRD or Koni shocks, and ground control springs which also have a threaded spring perch and do the same thing.
if ride height adjustabililty is important to you, coilovers are a good option.
if it is not, springs and shocks will probably do what you want for a bit less money. It is up to you to figure out how to match the springs/shocks properly though.
Old Feb 24, 2004 | 06:56 PM
scionxb04's Avatar
tein s tech....not stiff....i could compress the tein's much farther with my body weight then i could the stock springs....the stock springs are MUCH stiffer then the tein s tech's....i own them....the car rides much smoother....bumps are not as sharp when i go over them....car handles much much better....cant say 1 bad thing about them....im running the eibachs on my civic....both are very good springs....for my xB the tein's were the better choice when i asked around from some friends around here who own them.....plus the spring drop is .2 lower in the front....instead of lower in the back like the eibach's....why did eibach do that anyway? just my 2cents if it helps anyone....
Old Feb 24, 2004 | 07:16 PM
UrbanDrum's Avatar
Chances are you won't need more then the Ground Control kit...
Old Feb 25, 2004 | 04:05 AM
BigBadWolf's Avatar
Default Thanks .... for the edjuma Ktion.
I am looking for the best ride comfort possible, since this is going to be my next dialy commuter. Lexus's ride if possible. :o
BTW: Would dealer install stuff not sold thru them? If not, anyone know an "Honest" shop up by my way? website
PS:Still have not decided, narrow my choices to xA, tC or civic LX. Not a Mz3 thou, Just not a real bargin..
Old Feb 25, 2004 | 04:12 AM
JDMxB's Avatar
Let hope i get it right this time :lol:
It depends on what series of coilovers you choose--The Tein SS that is slated to be released any time now is 16 way damper adjustable--so you can go from comfort to sporty if you choose. The Tein Wagon series is tuned for comfort.
Think about it this way--no springs can be better than a full coilover setup--a quality one that is, because they actually mate an appropriate spring to a specialized shock, in order to create a perfect match for the vehicle.
I'm on Tein Coilovers--and it is much much smoother than my SPY springs.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
