Low Tire Presure Warning Light, But tires are actually Over
Old May 19, 2005 | 08:16 PM
Master_Shake's Avatar
Default Low Tire Presure Warning Light, But tires are actually Over
my tire presure waring light just went on on my tc
I checked the tires and they are all over presure not under
I had read that the plant over fills the tires for transport
is it possible that the presure sensor was set to that higher presure and now that some has leaked it's going off thinking that they are low?
Old May 19, 2005 | 08:56 PM
2eZee's Avatar
Default s
reset your tire warner look in the manual
because if they are all over but one is lower than the rest, it will sense an underpressure and trigger it until its reset
LOOK IN MANUAL woohoo
Old May 19, 2005 | 09:14 PM
Default Re: s
never asked how to reset it
I have read the manual
perhaps you sould have read my question before the reply?
Old May 19, 2005 | 09:16 PM
Rivulent's Avatar
Default Re: s
Don't pounce just because you didn't say "I reset the light". Take your car into the dealership, say it's still not going off. They will fix it.
Old May 19, 2005 | 09:19 PM
SCI_TC_GUY's Avatar
the light doesn't indicate LOW tire pressure.....it indicates a CHANGE or DIFFERENCE in tire pressure.....it's done by measuring something to do with rotation amount and rotating mass I believe......if you check all tires and get them to the same pressure, then reset the light, it will be all good....
Old May 19, 2005 | 09:35 PM
hehehe
ok it's prebably my fault
I didn't phrase the question properly
thanks for the replies
I'm not having a problem resetting it
I know how the thing works
was just funny that the low tire presure light goes off and all the tires are OVER presure
like I said, I had read that the plant over fills the tires for transport
has anyone else had a problem with the sensor being set to an overinflated presure?
was funny to my eye the one tire looked low, and it turned out to have the most air in it
I'm going to adjust them to 32/29 and reset the sensor
Old May 19, 2005 | 10:16 PM
k_splay's Avatar
ok, one more time.. the 'low pressure warning light' doesn't sense pressure -- the ACTUAL pressure does not matter. The way that it works is that when a tire has a pressure that is INCONSISTENT with the others, it will rotate faster/slower than the others, and that is when the light comes on.
Overpressure doesn't make a diff if ALL the tires are over pressure.
So, after resetting the light and your tires are at the same pressure, if it still comes on, then take it to the dealer.
-K
Old May 19, 2005 | 11:45 PM
ravidavi's Avatar
Originally Posted by k_splay
The way that it works is that when a tire has a pressure that is INCONSISTENT with the others, it will rotate faster/slower than the others...
What you are describing is an indirect pressure monitoring system, which uses the car's ABS to detect tire pressure based on rotation speed as you said.
However, all 2006 model year cars (and the 2005 tC I suspect) must use a direct method, which uses pressure sensors to directly measure pressure.
Ravi
Old May 20, 2005 | 12:39 AM
txjcb's Avatar
Check your spare tire it should also have a sensor
Old May 20, 2005 | 04:39 AM
j23seatown's Avatar
Default tire pressure reset
Its in the glove box top left. its the only button in there
Old May 20, 2005 | 02:21 PM
JasonH's Avatar
Sounds like your're just hitting the reset button until the light turns off. You need to hold it until the light blinks to reset the system. That will keep the light from coming on until you actually have a pressure problem.
Old May 20, 2005 | 03:41 PM
Daemon1313's Avatar
Ravi
Actually this is the type of tire pressure monitoring system used on the tC from my understanding.
As far as the NHTSA requriements go only 20% of new cars are required for the 2006 model year. It is not required on all cars till 2008. Considering the amount of cost cutting they did on Scions, I doubt you will see it on them till 2008.
Old May 21, 2005 | 03:58 AM
terra_tC's Avatar
overinflation is just as bad as underinflation....
im glad every car will have it by 2008, well at least the new ones
Old May 21, 2005 | 10:11 PM
SquallLHeart's Avatar
hmm.. well i remember blowing out my rear right tire and the light didn't come on... i dunno... does it really work??
evolving_machine
Oct 21, 2023 01:16 PM
scionlife
371
Jun 2, 2015 11:00 PM
evolving_machine
Jan 13, 2015 08:04 PM
toyotaisme
Jan 10, 2015 10:24 PM
STCxB
11
Jan 9, 2015 04:30 PM
