people with airbags an compressors or tanks under the car..
Old May 26, 2005 | 10:09 PM
Soto's Avatar
Default people with airbags an compressors or tanks under the car..
does anyone got em there an do they mess up when water hits them
Old May 26, 2005 | 10:33 PM
crayonBOX's Avatar
i havent placed mine under yet, but ive done my research,
from what ive heard, some compressors dont work well when mounted upside down (apparently viair is one of them) tanks, there should be no problem. as long as you dont put the components in locations where water will direcly splash or spray on them, many ppl havent had any troubles
Old May 26, 2005 | 10:56 PM
Soto's Avatar
dang my compressors are upside down i havent finished installing everythuing yet i just got my stuff bulted down
Old May 30, 2005 | 05:43 PM
scion1616's Avatar
THIS IS NOT TRUE. i have a viair 380c under the car with my tank. i havent had the first problem at all
Old May 31, 2005 | 02:26 AM
Sittin_Pretti_Box's Avatar
Shouldn't be much of a problem. Run a water seperator if you want, but I hear those aren't much of a help anyways. If you got a tank with a port at the very bottem facing the road, then just unplug it every once and awhile if you feel needs to get any water drained out.
scion1616, what kit are you running on your car? I am thinking of getting the Easystreet front struts and either 2500lb bags in the rear or the easy street rear kit. what works best for your box?
Old Jun 6, 2005 | 09:22 PM
sprslug_182's Avatar
the rear kit from easy street will get lower and it is also easier to install. You would need brackets fabbed in order to install the bellows. I know the bellows wont get as low either.
Old Jun 7, 2005 | 07:43 PM
ssfastlane's Avatar
Do you have any pics of your tank mounted underneath ? I'm going the same route so I can move my drums in and out..
Thanks!!
Old Jun 8, 2005 | 08:09 PM
sciondrgn's Avatar
Be Carefull with Easy Streets..
There not just bolt on you have to drill through your under frame rails and grind off some of the passenger side top mount to get the to fit..
Im on my second set.. Im switching over to EAI as soon as I get the money to..
The Sleeve Bags that Easy Street Uses are flimsy.. I busted my drivers side rear today while heading to lunch
Old Jun 10, 2005 | 09:55 PM
mrgeorgegarcia's Avatar
sIcKsCiOnS
i just about had it with easy street, i have not even taken the xb for a ride to see how the air ride really drives and while parked in my garage the rear driver side bag just burst and dropped immediately, checked the bag and it some how came undone from the factory compression seal.....what next....it just makes you want to say screw this......and go back to the springs and struts....tried calling airlift all i get is a busy signal.....i should have just kept my money.
Old Jun 10, 2005 | 10:36 PM
sciondrgn's Avatar
I agree with you man.. there sleeve bags are horrible and I dont trust them on my box.. i was riding down the road when mine popped and nearly made me run off the road.
Im sending mine back to them and they will replace it under warranty but I doubt I will re use them.. Im saving up for the EAI kit and rims right now..
Ive had several air ride vehicles and its sad to say but the Easy Street Stuff is starting to look like Aim products =\
Old Jun 13, 2005 | 09:27 PM
ShortBus843's Avatar
I had Viair compressors under my blazer, and everything was fine. Ive had it done for like 2 years
Old Jun 13, 2005 | 09:32 PM
dannyb's Avatar
i have 2 years with my silinders and i have no problem when i had my air bags it was a paint in the but that a hose broke a bag is pop or the valves but the point is that i have everything under the car and i had no problem so far the tank and compr
Old Jun 14, 2005 | 01:17 AM
in english please?
Old Jun 14, 2005 | 01:42 AM
sIcKsCiOnS
i took the whole easy street setup out to day, i just do not trust the bags and i dont want the aggravation, so i am going to sell it.
Old Jun 14, 2005 | 06:00 AM
What would you guys recommend for the front? I am gonna use 2500lb bags in the rear and such. Think the EAI's will ride nice at all still? IMO bags are a lot smoother, but i've never liked sleeve bags as well.
Old Jun 14, 2005 | 08:49 PM
sciondrgn's Avatar
Im gonna go EAI all around with mine.. Prob the cylinders up front an there 2500's in rear..
Old Jun 28, 2005 | 08:06 AM
J_A_Trevino's Avatar
so did anyone have pics of their tanks and compressors under their xb?
Old Jun 28, 2005 | 03:41 PM
sciondrgn's Avatar
Ill get pics for you when I move it all down there.. Just ordered another 450 compressor to add to the system
Old Jun 28, 2005 | 05:00 PM
thanks
Deltafan909
Photography & Video
Jul 4, 2015 04:25 PM
trikkonceptz
Jun 7, 2015 01:46 AM
dross93ranger
Apr 30, 2015 12:50 PM
Zombiecustoms
Apr 19, 2015 11:13 PM
fur_pig
Scion tC 1G ICE & Interior
Jan 27, 2015 12:52 PM
