Front camber ?
Old Jun 5, 2005 | 03:30 PM
JDMJim's Avatar
Default Front camber ?
I have installed the Easystreet strutbags an got the car back on the ground(literally). WHere did so much positive camber come from? Is there an easy fix like cambolts or something? I can't rock the spindles in any further. The camber is +1.5 or 2. Dropping the car bows out my front fenders. cuz of this camber and I won't drive it like that anyway. What is the solution?
Old Jun 5, 2005 | 07:56 PM
Spider13's Avatar
Easy street got a little happy correcting for the negative camber of the drop. Best bet to correct it is camber plates, but they seem to be somewhat hard to get. I've got camber bolts, but really need more. You really need 3-5 degrees to get it to tuck right.
Old Jun 5, 2005 | 07:59 PM
hotbox05's Avatar
even with camber plates and or bolts there that problem with the fender being pushed out . you could always slot out the two hole on the bottom of the stru to attain camber .
Old Jun 5, 2005 | 10:27 PM
Spider13's Avatar
There isn't much matrial on the Easystreet strut to try and slot. I wouldn't dare do that on a car I had to drive.
Old Jun 5, 2005 | 11:56 PM
JDMJim's Avatar
I agree. I'll contact them tomorrow for a resolution.
Old Jun 6, 2005 | 12:21 AM
mrgeorgegarcia's Avatar
sIcKsCiOnS
let us know because i am having the same problem
Old Jun 6, 2005 | 03:05 PM
Spider13's Avatar
I'd like to know as well.
Old Jun 6, 2005 | 04:04 PM
Dewmerz's Avatar
Cusco camber plates might get you closer to 0. Check with MyBox.
Old Jun 6, 2005 | 09:12 PM
sprslug_182's Avatar
go and get your box aligned at ride height, if you want the camber to be as negative as possible, have your ride height set to as low as you will drive safely. I did this at network alignment here in phoenix AZ. They let me drive my own car on the rack, I adjusted the suspension where I wanted it, and I let them go to work. My tires love me long time, and I drop it all the way with it barely touching the inner fender. To furtehr help it not touching, remove the plastic inner fender and get an exacto knife.
Old Jun 7, 2005 | 01:04 AM
sIcKsCiOnS
remove the plastic fender and what is the exacto knife for, are you modifying the plastic liner explain please.
Old Jun 7, 2005 | 03:04 AM
hotbox05's Avatar
a slotted strut , ( only like half inch or less ) is just as safe as airbags , yeah something could pop or mess up but if you do it right there shouldn't be any problems.
Old Jun 7, 2005 | 03:23 AM
Spider13's Avatar
Slotting these struts would leave a tiny sliver of metal left on the outside. It might be okay on a show car. But there is no way that would be safe, espeically after you heat it by cutting the slot.
Old Jun 7, 2005 | 03:31 AM
MyBoX's Avatar
Hotbox, you know my situation, I was about to do that to add more negetive to what I already have and move my new wheels towards body more but nope, I don't think its safe, so I might end up leave it they way it is !!
About the front plate, they are on back order as of now, but I should have six sets in about two weeks,
Sean JDMP
Old Jun 7, 2005 | 05:47 AM
hotbox05's Avatar
I would slot the upper bolts inwards!!!
Old Jun 7, 2005 | 07:07 AM
MyBoX's Avatar
That might work for a little but then you have to think about the bag and body clearance, for some one like me with that much camber already, Sean
Old Jun 7, 2005 | 03:49 PM
JDMJim's Avatar
yeah, I'm not cutting that strut. could void warranty as well.
Old Jun 7, 2005 | 06:08 PM
hotbox05's Avatar
I understand everyone's points I was just offering up a suggestion good or bad.
Old Jun 11, 2005 | 02:59 PM
JDMJim's Avatar
Where can I get the camber bolts? I checked with NTB and they don't have any.
Old Jun 11, 2005 | 05:10 PM
sIcKsCiOnS
i ordered some from
Ptuning.com
Old Jun 12, 2005 | 02:34 PM
SciFly's Avatar
when you alter camber from stock do any of you guys compesate the toe-in?
(i just know we have to do this on Model T's with their major, positive camber. It's the rolling hoop effect.
Tilt the hoop and it wants to roll in a curve in the direction of the lean.
We T fine-tuners adjust toe-in to neutralize that effect and make for a lot less tire scrub and remove the tendency of a T to "dart" off to one directin or another.
But those are skinny tires on the T, not wide treaded tires.
-just this question answered please, I don't mean to detract from the thread direction beyond getting some know-what about toe in on a modern car having neg. camber.
thanks
scionhawaii
13
Jun 19, 2015 03:59 PM
HeyyJose
Mar 11, 2015 02:15 PM
jcraff3
Feb 20, 2015 11:41 PM
TheTripleC
Jan 4, 2015 06:46 PM
kleecker
Jan 2, 2015 08:09 PM
