brake slamming
Old Jun 14, 2005 | 08:06 PM
FainT's Avatar
Default brake slamming
what kind of problem can be caused by slamming on your brakes with a brand new tc. i did it the other day and then i had read the manual and just curious what problems that might cause.
Old Jun 14, 2005 | 08:08 PM
VIP_tC's Avatar
well you could warp your rotors... in which case you will feel your steering wheel vibrate (epecially when braking), but chances are that you did no harm.
Old Jun 14, 2005 | 08:11 PM
indecisive311's Avatar
Scion Noics
Yea its probably nothing. Just get into the habbit of long-braking.
Old Jun 14, 2005 | 08:14 PM
VIP_tC's Avatar
Once you break in your brakes (seating the pads to the rotors) you are fine. Its just with the brand new equipment it is easier to screw them up.
Old Jun 14, 2005 | 08:15 PM
Lonely_Raven's Avatar
If he stomped on the brakes, shouldn't the ABS have kicked
in and pumped him to a stop? If so, then I imagine it to be
difficult to warp rotors and glaze pads.
Old Jun 14, 2005 | 09:24 PM
xnevergiveinx's Avatar
you can glaze pads if you constantly ride the brake hard, this will heat up the brakes badly, causing them to warp...thats ok, it'll give you a reason to buy some performance pads and crossed drilled vented rotors
Old Jun 14, 2005 | 09:36 PM
05silvertC-'s Avatar
wouldn't hurt really anything except maybe warp the rotors or put a glaze to the,m that may make periodic noise but functionally it should hurt nothing.
Old Jun 14, 2005 | 10:13 PM
FainT's Avatar
how long does it take to actually break in your brakes. i kno the manual says about a 1000 for your motor but i forgot what it said for the brakes
Old Jun 14, 2005 | 10:56 PM
engifineer's Avatar
Only if he braked hard enough to lose traction
Old Jun 14, 2005 | 11:26 PM
Stoptech's Avatar
This is what we suggest for pad/rotor bed in/break in
http://www.stoptech.com/whitepapers/bedincontents.htm
Old Jun 14, 2005 | 11:27 PM
sciontc_mich's Avatar
usually it's about 250-300 miles of (braking miles) which could translate into 1000 miles driven..
EDIT: I will say that stoptech's approach to breaking in.. did work, I was easy on the brakes for 1000 miles, then began to develop a squeal.. I tried stoptech's way and no more problems.. Guess being too easy on brakes can actually be a bad thing just like too hard on the brakes too..
Old Jun 14, 2005 | 11:35 PM
the_whoster's Avatar
hehee... those stoptech guys..
one's got a e36 M3, another one's got a clean 350z.
they're manufacturing and headquarters are run out of office buildings like 3 minutes from where i live. :D
i'm considering walking in and asking them for a job. even answering phones.
Old Jun 14, 2005 | 11:49 PM
Stoptech's Avatar
It is true that you can't just use the brakes too easily. The main point of the bed in is to warm up the pads and transfer the material over to the rotor, so you may not need 10 decelerations. You may only need 6 or 7 for a stock system. The more aggressive street pads need to be driven aggressively to stay bedded in.
As for open positions, drop on by and fill out an app. We may have something for you.
Old Jun 15, 2005 | 12:01 AM
i'll be dropping by tomorrow. :D
gqdabien
Oct 8, 2015 05:36 PM
Darrenohooligan
Sep 26, 2015 07:21 AM
Klashan
Sep 24, 2015 12:39 PM
DannyBoy65
Sep 21, 2015 06:23 PM
Subaru86
Scion FR-S Aero & Exterior
Sep 14, 2015 12:39 PM
