Strut or CV-J blown?
Old Jun 16, 2005 | 04:59 AM
xtremeOrange's Avatar
Default Strut or CV-J blown?
So they put in those speed humps on the road to my house, but they have yet to paint those white stripes on them. Unfortunately I wasn't aware of this new development as I haven't been home for a week, and ended up slamming into one (about 25...). I'm on DF210's, and anyone else that is can vouch for the horrible thump and other noises that accompany such speed. Anyhow, the results - whenever I hit a bump or road imperfection at speeds over 20mph, and whenever I take sharp-ish left turns at low speeds, there's a thumping noise from the right front wheelwell... During the left turns, it's a soft, rhythmic thump-thump-thump in about 1/2 second intervals. The bumps and imperfections result in a solid WHUMP, also from the right front. Just my luck, my warranty expired about 2 hours before all of this (36k miles).
With the descriptions aside, I'd like some input on what you all think is wrong... Again, I'm on DF210's w/ stock everything else if that means anything. Is my strut or CV-joint blown? Or did I just knock something loose? Ride- and driving-wise nothing has changed from before, it still handles the same and rides the same - just those bumps and turns at those speeds.
If anyone knows what's up, pllleeeeeaaasssee drop a line... I'm tripping out a bit since I have no clue what could be wrong. TIA for any help!
Old Jun 16, 2005 | 05:09 AM
eggie's Avatar
Hmmm, I wanna say strut is toast.
You could easily tear down the left side and find out pretty quickly.
Old Jun 16, 2005 | 06:18 AM
Tear down how? And why the left? It's the right side that's having these symptoms... or do you mean to compare the good, left side to the right?
Old Jun 16, 2005 | 06:52 AM
hotbox05's Avatar
your strut is gone but with df210 springs the warranty wouldnt have covered the struts anyways. the cv also sounds bad if u hear a clunk or clicking while turning.
Old Jun 16, 2005 | 02:08 PM
eggie's Avatar
Misread, I meant right.
Take wheel off. Take strut out. take spring off. test strut. If you can easily compress it, it is toast. Since everything on the right is out, check the cv joint.
Old Jun 16, 2005 | 02:23 PM
blkyotabb's Avatar
i had a similar problem and it was the strut but it was just something kncked loose
the first thing i would check it the nut at the top of the strut i think it 15mm or close and a wobble extention that what i did and worked great let me know
Old Jun 16, 2005 | 03:17 PM
Aight, thanks for the help peeps, I'll be testing it later today. eggie and hotbox, or anybody else - how do I test the cv joint? Just wiggle it and listen for the same clunking?
Old Jun 16, 2005 | 03:53 PM
squirrel's Avatar
If you make a slow u-turn to the left, and hearing clicking coming from the right side, you';re CV joints is in need of replacement.
Since you have DF210s, I'd also check to see if the bumpstop is still in one piece or not.
To check the strut, push down on the bumper. It should rebound once w/o making any noises.
Old Jun 16, 2005 | 04:04 PM
sciondrgn's Avatar
I would call the city or whoever placed the speed bumps there and explain your situation and make them pay to have everything replaced.. and take some pics if they havent already painted them yet or put signs up..
Old Jun 16, 2005 | 04:16 PM
eggie's Avatar
^^ Good call! ^^
Old Jun 16, 2005 | 04:26 PM
squirrel's Avatar
^^ Good call! ^^
Actually, speed bumps are placed on certain streets after a Speed/Traffic Survey has been conducted.
Here's good example.
Say it was raining for a good three weeks, and then its clear. You hit a good size pothole, you blow a tire and bend a rim.
Believe it or not, this is considered a Traffic Collision are the driver is at fault under 22350 CVC, Speed for Conditions.
The driver was traveling to fast to react to the conditions of the road, and the damage would not have occured if the driver was traveling at such speed to adequately react to the conditions.
So, if damage occured from hitting the speed bump, the car was traveling to fast. Some, not all, cities will have the speed bumps painted and or signs posted.
Don't ask me how I know all of this.
Old Jun 16, 2005 | 04:48 PM
So apparently my cv is blown... I called the dealership and was thrilled to learn that it'll be replaced under the 5yr/60k mile warranty... which is exactly why I kept my stock springs after swapping the DF's on :D Now all I need to do is schedule the two days they need to replace it... ugh. Thanks for the help to all that replied, I greatly appreciate it.
kb1sxv
Oct 21, 2015 05:00 PM
babyfac3pn01
Oct 19, 2015 07:24 AM
DannyBoy65
Sep 21, 2015 06:23 PM
OpTicaL
Sep 16, 2015 10:25 AM
goatbelly
Jul 12, 2015 10:13 AM
