I know *SOME* of you have ripped your dash apart... HELP!!!
Old Jun 18, 2005 | 11:18 PM
InTheWASide's Avatar
Default I know *SOME* of you have ripped your dash apart... HELP!!!
I'm looking to change the LEDs in the gauge cluster and the climate area from their current amber, to a blue that matches or is close to the blue of a cold cathode. Essentially, if it's amber stock, I want it blue... the stuff inside the head unit I'm leaving alone though. (I got mine from oznium.com if that makes a difference)
What I need to know, and I know some of you have dismantled your car before...lol.. is what kind and size of LEDs do I need to accomplish this? I also want to change the bulb for the little cubby hole behind the shifter to the same color.
If someone can give me the specs for the LEDs, or a website I can order these from or BOTH, that would be GREAT!!
Thanks in advance! I await your expertise!!
Old Jun 18, 2005 | 11:19 PM
reign's Avatar
They're not bulbs. They're LEDs. If you look in the Tech section you will find a howto.
Old Jun 18, 2005 | 11:25 PM
engifineer's Avatar
These LEDs match: http://www.lc-led.com/Products/department/5
They are surface mount, so you will need a little soldering experience.. here is a stick on soldering just in case:
https://www.scionlife.com/forums/vie...61793&start=25
The console ones will be a bit dim. A couple of us are planning on figuring out which components need to be changed to fix this.
Heres the how to on the gauges:
https://www.scionlife.com/forums/vie...=37747&start=0
Old Jun 18, 2005 | 11:30 PM
Awesome! Such quick replies too... You've been trained well! hehe jk. Thanks. It's much appreciated. Keep in contact if you figure something out with the console. I can always hold off on that
Old Jun 19, 2005 | 02:08 AM
dctennis10's Avatar
The little cubby hole light is equivalent to a #74 LED i believe. I got mine from www.superbrightleds.com
*edit*
here is the exact page, its towards the middle:
here
wiltonhall
Jun 23, 2025 10:09 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
BlueMachine827
Jan 1, 2015 01:55 AM
brianmets5
Scion tC 2G ICE & Interior
Nov 22, 2014 10:38 PM
randode
44
Jun 29, 2004 04:19 PM
