Weapon R Cold Air Box Installed with Pics
Old Jun 20, 2005 | 11:08 PM
yellot00tr's Avatar
Default Weapon R Cold Air Box Installed with Pics
ok-i just got the cold air box today and it's been giving me some install problems. i have the redline tuning hood lift, which is installed on the drivers side of the engine bay. with the hood lift and the cold air box, the hood won't close. you can slam it down, but it might break the box or the hood lift-basically, don't try to force it. what i'm gonna do is take off the hood lift and reinstall it on the other side of the engine bay. the other problem which isn't that big of a problem is that my tanabe strut tower bar is also pressed against the top of the box. this is just touching it, but isn't really that tight against the cold air box. as of right now, i have the box installed, but without the top untill i get the hood lift moved.
Old Jun 20, 2005 | 11:17 PM
yellot00tr's Avatar
pictures i took really quick just to show how tight of a fit the thing is.
Old Jun 20, 2005 | 11:49 PM
acasanova's Avatar
hope you get installation worked out looks nice, any plans on dynoing it?
Old Jun 21, 2005 | 12:24 AM
yellot00tr's Avatar
i will as soon as i get the damned thing installed properly. i wanna see what the hp numbers are for the weapon r, the ram air kit, and the cold air box all together. in the other post about the cold air box i put a pic up of someone testing the temperature of the engine bay, the intake manifold, the outside or the cold air box and then inside of the cold air box. the temp difference from engine bay to the inside of the cold air box was 50 degrees. that's a pretty big difference. i'm hoping that'll add some hp.
Old Jun 21, 2005 | 03:20 AM
ZaZaTc's Avatar
So, how much is this cold air box ??? I also have a WR intake and i'd be interested in seeing the dyno compared to that doesn't have the cold air box.
Old Jun 21, 2005 | 04:12 AM
EVILDAVE's Avatar
Try putting some spacers under the mounting plate for the hood lift before you go drilling.
Old Jun 21, 2005 | 05:42 AM
Gambit7's Avatar
Where did you get the box from?
Old Jun 21, 2005 | 06:45 AM
yellot00tr's Avatar
got the box from weapon r-i just found out from redline that u can't put the hood lift on the passenger side. this is really screwing me up now.
Old Jun 21, 2005 | 03:51 PM
Marshall's Avatar
Looks like Fabrication time.
A Dremel or wheel cutter tool will take care of that issue.
Old Jun 21, 2005 | 04:06 PM
yellot00tr's Avatar
i finally got the box to fit right. i had to move the redline hood lift to the passenger side so i could get the hood to close. next step-dyno
hoodlift installed on the passenger side:
cold air box installed
Old Jul 1, 2005 | 10:11 PM
yellot00tr's Avatar
i think i'm gonna have the box painted-just not sure what color yet. i want superwhite, but it's gonna get dirty too fast. i may just go with red or blue to match the wiring in the car.
Old Jul 1, 2005 | 10:27 PM
matty-tC's Avatar
looks good
and you can't go wrong with black
Old Jul 1, 2005 | 11:00 PM
maximus96's Avatar
i want to buy a oil catch can like that. what model # is that? i see alot on ebay but don't know which fits. i read the tc has different hose diameters. did you have to modify yours to fit?
Old Jul 2, 2005 | 01:54 AM
reagulator's Avatar
what did you wrap the intake with?
Old Jul 2, 2005 | 03:28 PM
squirrel's Avatar
Its the GReddy universal oil catch can. Unbolt the PCV valve and measure the diameter of the valave. That'll let you know what size you need.
Old Jul 2, 2005 | 03:55 PM
dmxsoulja3's Avatar
Get a Ground Fusion ground wiring kit, yours looks a mess. The box is nice though
Old Jul 2, 2005 | 03:56 PM
KINGxOFxSKA's Avatar
Unique Scionikz
daaamn u've got a lot of wires coming off yer battery....
Old Jul 2, 2005 | 04:02 PM
DTRUONG_112's Avatar
what are all those wires for?
Old Jul 2, 2005 | 04:09 PM
Unique Scionikz
seems like a homemade grounding kit...?
Old Jul 2, 2005 | 06:36 PM
gwtc's Avatar
This is kinda off-topic, but do you guys think the redline hood lift will work on a carbon fiber hood? thanks.
