How do you remove the silver accents on the steering wheel?
Old Jul 8, 2005 | 03:30 PM
jayrod's Avatar
Default How do you remove the silver accents on the steering wheel?
as well as those on the doors and on the shifter? Can it be done without taking the out the larger components they're attached to?
And yes, I did try searching... for three days. Search on this site could use a boost.
Thanks for any help!
Old Jul 8, 2005 | 03:49 PM
stick_1NZ's Avatar
color-match paint it. that'll solve the question.
Old Jul 8, 2005 | 03:55 PM
jayrod's Avatar
yeah, that's the plan. However, painting them correctly would be much easier if they were outside of the car. that's what I'm getting at.
Old Jul 8, 2005 | 04:20 PM
exklusiv12's Avatar
was also wondering how to get those ones off the steering wheel and door with out taking off the whole panel. i think the one on the shifter you have to take out the center console. but that comes out pretty easy i think its one screw and thats it.
Old Jul 8, 2005 | 04:36 PM
jayrod's Avatar
the trim ring around the shifter comes off with the center console, and yes, it does come off easily. The piece actually on the shifter, however, is a different story.
Old Jul 8, 2005 | 07:58 PM
hotbox05's Avatar
you either use a small flathead screwdriver and pop them off , probably breaking a few of the pieces that hold them on or you remove the airbag and remove them from behind. i popped mine off they still stay on no problems and one side is missing almost half the lil pins.
Old Jul 8, 2005 | 08:25 PM
jayrod's Avatar
does that apply to the door pieces as well?
Old Jul 8, 2005 | 08:28 PM
sciondrgn's Avatar
If your Referreing to the Panel for the power windows and switches . . Take your door panel off and pop them out and un hook the wire.. You might could get away not taking the door panel off but I wouldnt risk breaking the plastic clip on the back..
do it right the first time ya know .. hope that helps
Old Jul 8, 2005 | 09:23 PM
exklusiv12's Avatar
thanks for the info everyone
Old Jul 10, 2005 | 04:28 PM
jayrod's Avatar
Thanks for the info everyone! I got the door accents and the ring around the shifter off and painted. Still not really sure about those steering wheel pieces.
Is there a technical manual somewhere that details their removal?
Old Jul 10, 2005 | 05:13 PM
BEASTXB's Avatar
Thanks ALOT I was looking for something like this forever!!!
Old Jul 10, 2005 | 05:38 PM
eggie's Avatar
I taped my steering wheel off and shielded the interior with news paper around the area I was goingt o spray. Worked fine for me.
Old Jul 10, 2005 | 06:25 PM
YELOSUB's Avatar
Wagonistas
For those still needing questions answered, PM miniH2 in the Desert and Salt region because he has painted every interior piece that needs painting including the accents on the steering wheel...
Old Jul 11, 2005 | 01:49 AM
hotbox05's Avatar
i just slipped it out from pushing up with a screwdriver from the front of the template. alot easier imo
Old Jul 11, 2005 | 02:06 AM
Max's Avatar
Max
i just slipped it out from pushing up with a screwdriver from the front of the template. alot easier imo[/quote]
Correct. You MUST go in from the front. There is a metal tab you must push back. The cover will just pop up when pushed in. Something thin and long like a knife (the butterknife variety works very well. If you go in from the back, there is a rigid plastic piece that you can break.
Old Jul 11, 2005 | 02:41 AM
hotbox05's Avatar
correctamundo
Old Jul 11, 2005 | 03:37 AM
jayrod's Avatar
Correct. You MUST go in from the front. There is a metal tab you must push back. The cover will just pop up when pushed in. Something thin and long like a knife (the butterknife variety works very well. If you go in from the back, there is a rigid plastic piece that you can break.[/quote]
True story, however, I ended up taking both front door-panels off. It would have been much easier if I would have known about that damned metal clip.
CombatmedicR56
Nov 12, 2020 01:53 AM
fur_pig
Mar 20, 2020 04:28 PM
mischman
Jan 14, 2015 06:07 PM
FurionAlpha
Scion tC 1G ICE & Interior
Jan 12, 2015 08:25 PM
Beesh
Jan 9, 2015 06:30 PM
