How accurate is the Tc's outside temperature reading?
Old Jul 18, 2005 | 06:10 AM
fromos's Avatar
Default How accurate is the Tc's outside temperature reading?
I've been gettig readings 10-20 degrees above what the temperatue really is this summer. Am I alone here?
Old Jul 18, 2005 | 06:13 AM
hatchbox's Avatar
mines is not that drastic, but i do think it is not too acurate...i choose to ignore it and have the clock display at all times
Old Jul 18, 2005 | 06:21 AM
InTheWASide's Avatar
is it right after you start it up? After I've been driving a bit it seems to get more accurate. I;d assume within 3-5 degrees
Old Jul 18, 2005 | 06:43 AM
scoobyroo2002's Avatar
yeah when you first start out it's some outragous number...then drive for 5 minutes..then that is the accurate reading.
Old Jul 18, 2005 | 06:52 AM
maximus96's Avatar
i think mine is off about 2 degrees. when i drive by those signs that displays temps, i'm always a few degrees off.
Old Jul 18, 2005 | 06:55 AM
either that..or those signs are 2 degrees off..i dont trust those bank signs..they are all different..even if they are next to eachother.
Old Jul 18, 2005 | 07:57 AM
Dr_Isotope's Avatar
It's as accurate as the temp sender the ECU reads to measure intake temps... at freeway speeds, those temps match. I'm using a ScanGauge to monitor IAT (Intake Air Temperature) among other things.
Old Jul 18, 2005 | 11:44 AM
yokillr's Avatar
one time my gauge read 102, then 10 minutes later it read 82.
Old Jul 18, 2005 | 12:20 PM
fearturtle44's Avatar
My wife's subaru does the same thing. Initial reading is way off and then after 1-2 minutes, it reads normal. Just use it as a pretty good reading but not 100%. But then what is 100% correct for temperature reading???
Kevin
Old Jul 18, 2005 | 01:01 PM
LGS-Static's Avatar
Same here: Wifes MDX will read above normal until u drive for a bit.. its just cause youre sitting in the HOT SUN!
my tC has read 119 before dropping to 91... MDX has read 110 before dropping to 89. close enough for me!
its HOT out, thats all I need to know lol
Old Jul 18, 2005 | 03:28 PM
jaydub's Avatar
My outside temp gauge read 119 last week... and it was correct!
Old Jul 18, 2005 | 03:41 PM
EWWW 119? sucks!
Old Jul 18, 2005 | 03:51 PM
jaydub's Avatar
EWWW 119? sucks!
definitely. Up to about 110-112, it's bearable for short periods but past that it's just wrong even for a few moments.
I think they said the temp they take inside your car (they call it a carmometer here on the news) said 155°... try touching your steering wheel after that!
Old Jul 18, 2005 | 03:57 PM
engifineer's Avatar
every bank sign or gauge you read will be "off" by a little. That is because it literally is not the same temp at your car as it is near the sign, the sun is shining on each different, etc. Take a good digital thermometer outside and walk around with it.. you will see what I mean. But when you first take off the gauge in the tC will be way higher than what is actual. After driving a few minutes you will see it fall.
And 2 degrees off in general is not exactly a horrible thing... we arent doing climate controlled chemistry experiments using our tC temp gauge.
Old Jul 18, 2005 | 04:01 PM
rjj130's Avatar
Yeah, I don't think all thermometers are right on with each other, it's just to gauge what the outside temp is...
What, do you go out in the morning to see how warm it is before dressing for work?? haha....
And I also get the off the scale temps when I start the car, but then it starts falling pretty quickly once you get moving...
Old Jul 18, 2005 | 04:12 PM
Bluechualappa's Avatar
The highest mine read was 122F and it was only outside for an hour!
Old Jul 18, 2005 | 04:46 PM
EWWW 119? sucks!
Worse then that..I have a metal shift ****..can you say OUCH!!!
Old Jul 18, 2005 | 04:47 PM
DJ_Rejected's Avatar
Let's see, how hot is it outside right now...130! Oh yeah, then you have to add the temperature of a runway (10-15 degrees more) plus flak vests. Welcome to Afghanistan!
Old Jul 18, 2005 | 05:02 PM
Shocker's Avatar
That is wicked hot, its not much different at home though, i am a lifeguard at SilverWings pool at Luke, it is definetly 120 for a majority of the day.
Old Jul 18, 2005 | 11:26 PM
iowagary's Avatar
Anyone know where the thermometer is? Is it just some heat sensor that the car uses for other things that Scion decided to give you a little LCD readout of? It would be cool if there was some special debug mode where you could get readings of everything else - I bet there is some cool stuff that the computer knows about in there.
