my friggen headlights AGAIN
got my car back 2 weeks Ago, had the Passenger side headlight fixed, Because of water inside the headlight, They fixed it, i call them a Week later the other side is now doing it........NOW 5 min ago i look at the car and the side they fixed AGAIN has water in it, and this white Fog over it, From the inside?
im so annoyed right now, This takes time out of my Job
i allready lost the car for a Full day once...
NOW AGAIN!!
im really Re-thinking the TC now...
NOW AGAIN!!
If your tC headlights are anything like those on my xA (I assume they probably are) there is a rubber "boot" that is over the rear plug assembly. You need to MAKE SURE you get that re-seated correctly when you replace bulbs. That's your weather protection.
The tc does not have a boot like you are describing. It just seals via a rubber oring on the bulb itself. If the bulb was not seated correctly it could cause moisture to seep in. I changed my bulbs in the rain and a little water got inside but it evaporated and hasnt come back since.
Hatch and sunroof rattles are common with tC's, Jason. There has been a service bulletin for sometime now. Just get them fixed when you return to the dealer and be sure you take them in the car to hear the rattles. I wonder if the pull is bad brake bias or something. I don't have that in any of my cars.
vi3tb0i09
Sep 23, 2015 08:32 PM
atlantaemail
Sep 20, 2015 02:03 AM
