moonroof clearance caused my "hatch" rattle + fix
Old Jul 26, 2005 | 11:41 PM
tom's Avatar
tom
Default moonroof clearance caused my "hatch" rattle + fix
I don't think anyone has posted this exact "hatch" rattle problem and solution, so I thought I'd document for anyone else with these issues as part of your troubleshooting. My story is this...
When the temperature here jumped above 90, I started hearing a little rattle, which turned into a kind of clink-noise, which turned into a clink-rattle. The noise level was about as loud as I can snap my fingers, but it was like the sound of glass clinking against metal, or metal hitting other metal.
From the driver's seat, it sounded like it was coming from the hatch. When I hopped in back and had someone else drive, by putting my head right up to the rear roof glass, I could hear the noise in the roof area which extends from the C-pillar.
I took the car to the dealer once, they replaced the struts and my service report says this (I'll spare you the all caps-ness)
Check rattle in back hatch
Cause: Loose Stays, replace hatch supports
642231 back dr upper stay assy 1-sd r&r
2845 wpt3 0.20
A combination A
2845 wpt3 0.30
1 68950-ow261 stay assy, back door
1 68950-ow251 stay assy, back door
part#: 68950-OW261
count: 2
This appears to just be the TSB, which may have fixed some other rattle noise, but not my clink noise. When the clink noise became basically a constant rattle over even smooth-ish roads, I took the car back. The techs looked at it for a day, kept it overnight, called scion corporate for help, and ended up ordering some parts. It's worth noting that the tech told me something to the effect of "We sometimes have people come in with rattles that aren't rattles, but you definitely have a rattle. We'll get it fixed." In any case, the parts arrived a few days later and today they went to work again. Here's the invoice
Check rattle btw. sunroof and rear hatch
cause: poor clearance btw. sunroof and body. r&r headliner assy. z=r&r
glass roof track and insulate from body
743201 roof headling assembly r&r
2806 wpt 2.00
Z combination Z
2806 wpt3 1.0
FC 91,41 PART#: Count
I'd post pics, but there's really nothing to see. In any case, I didn't notice any rattles on my drive home.
Old Jul 27, 2005 | 12:27 AM
boombacloud's Avatar
I'm not sure I've heard the clink noise your talking about, but your desription of the other rattle from between the sunroof and hatch sounds like what I have happening.
Anyway, thanks for writing this up. I may be able to use it when I take mine in to the shop.
Old Jul 27, 2005 | 12:44 AM
engifineer's Avatar
Good info! Although I dont have it, the mysterious hatch rattles keep me reading in case I ever do get them.
If the body was coming into contact with the glass, this may be a possiblity of why some shatter. One pictured on here looked as if it buckled upward when it shattered. As if something compressed the assembly.
Old Jul 27, 2005 | 01:46 AM
tom's Avatar
tom
This is what I was thinking too. I was unable to make my clinky noise by abruptly applying (liberal!) pressure to the glass panel from above or below, but it's hard to tell what the glass is actually mounted to on the body.
For completeness, I think this is the picture in question: https://www.scionlife.com/forums/viewtopic.php?t=66488
alexxfender
Apr 1, 2015 03:06 PM
Cameron
12
Feb 2, 2004 06:46 PM
jdtjunior
Jan 25, 2004 08:25 PM
Vegasscion
Jan 21, 2004 07:00 AM
CBSIMONSEZ
29
Jan 2, 2004 09:57 PM
