Finally got the roof rattle but found a way to solved it!!
Old Aug 4, 2005 | 12:47 AM
materialboy's Avatar
Default Finally got the roof rattle but found a way to solved it!!
After a year of driving my tC I finally have the roof rattle and it's been annoying me for a couple of weeks. I got home today and decided to take a look what was causing it. It turn out that the hinges from the rod that attach to the wind deflector used to have greese and it dried out. I applied greese on it and the rattle is gone. This part is not inside the rubber seal but outside and it gets wet everytime it rains or wash my car. I'm sure you guys had figure it out but I just like to share it cause I'm happy again with my tc.
Old Aug 4, 2005 | 12:50 AM
maximus96's Avatar
thanks, good to know.
Old Aug 4, 2005 | 05:30 AM
Shadow_tC's Avatar
Sweet! I figured that's what happened with mine. I heard the noise coming from the deflector, but didn't know if it was bolts or if it just needed some grease. I'll take care of it. =)
- Desirée
Old Aug 4, 2005 | 05:37 AM
Setarcos4131's Avatar
If no one minds. could they just upload a pic to the component that ya'll are talking about? I have a slight idea but would like re-assurance. off topic but im also about to rip my hatch apart to find that rattle sometime soon. GRRR
Old Aug 4, 2005 | 06:47 AM
sorry I don't know how to put the pics here but if you check my gallery it's there.
https://www.scionlife.com/gallery/sh...php/photo/9939
Old Aug 4, 2005 | 12:10 PM
fearturtle44's Avatar
I applied wet lithium to most of the joints/hinges, etc. on moonroof and that fixed the rattle. For the hatch, good luck. As posted before, there have been at least 10 remedies but I don't think any one of them has been the ultimate answer. In fact there is a TSB which I am getting done in the near future that replaces the struts.
Let us know if you figure out the hatch rattle....
Kevin
Old Aug 4, 2005 | 12:21 PM
TCRS1_0's Avatar
Yeah greasing the wind deflector arm has already been covered before in this forum . It resolved some of my roof noises , but didnt cure all of them . The most constant and most annoying one comes from the rear panel of glass in the roof , before it goes into the hatch glass . I am suspecting(this is a theory till I get more information) the roof panel attaches to the vehicle and rests in a subframe . Im assuming in this subframe there are rubber mounts or soemthing that contain the actual bolts that connect it to the car . I believe this is where my sound is coming from , since when I reach back when doing down the road and pull down on the black piece of trim in the second sunroof the noise stops . I have been to the dealership numerous times over this issue and it never gets solved . Now I am lookin to take matters into my own hands since they have been no help . If anyone has a link to detailed images or schematics of how the roof is attached to the vehicle it might help in me figuering out this damn noise , then I will proceed to the hatch .
Old Aug 4, 2005 | 01:45 PM
raWr215's Avatar
what type of grease should we use?
Old Aug 4, 2005 | 01:57 PM
I used a wet lithium SPRAY found in all Auto stores. Just beware that it leaves a yellow color. So just watch where you spray. Not sure if they make a clear spray or not.
Kevin
Old Aug 4, 2005 | 02:56 PM
Kevin
Definately will post up information with some pics for you guys if i solve the hatch...and there is a TSB out that replaces the struts?! Never knew it could go that extreme. But definately I am going to take it into Toyota and get it checked out first...
EDIT:: Thanks Material Boy for the link...definately see what ur saying now...thanks again.
-Justin
Old Aug 4, 2005 | 06:19 PM
gingles's Avatar
Default hey
I just picked up my tC from the dealership. I took it down there to get the hatch rattle fixed...all he did was apply some padding around the edges and presto.....quite ridin from now on
Old Aug 4, 2005 | 08:39 PM
TCRS1_0's Avatar
Around the edges of what?
Old Aug 4, 2005 | 08:58 PM
gingles's Avatar
Default hey
around the edges where the hatch fits into the rear of the car
Old Aug 5, 2005 | 03:49 AM
JSVH's Avatar
I have had the Sunroof pop TSB done on my car. But is did not stop my rattle. But I picked up some grease and put it on said joint and it has fixed it. For now atleast ::knock on wood::
nice job
Old Aug 5, 2005 | 03:56 AM
CHI-BCP-TC's Avatar
As far as my Hatch rattle. I took the advice of a couple of people on here. First, when you close the hatch, dont slam it shut. Close it as slow as you can (after fully opening the hatch all the way) and then push down on it so you here it click. Also, I took some foam insulation (sticky on one side- comes in a 1/4 in side strip) and put it where the rubber stops are on each side of the hatch and also where those two cushions in the very back -attached to the hatch- meet with the screw on the bottom of the car it self.
As mentioned earlier, the hatch seems to have to much play because of the defective struts.
thats my 2 cents.
Old Aug 5, 2005 | 05:45 PM
smiracle's Avatar
Default Sunroof fix, Lithium grease
The spray lithium grease worked like a charm! Be sure to get both joints on each arm and put a towel behind it when you spray because that stuff is MESSY! No more rattles. This will not fix the POP however, as the TSB needs performed at the dealership first, then your roof will rattle. HAHA!
connertc1
Scion tC 1G Aero & Exterior
13
Jan 17, 2017 01:33 AM
usafscion
Mar 13, 2015 09:05 PM
carid
Feb 12, 2015 11:54 AM
silverslider
Dec 1, 2014 11:18 PM
sensez
34
Nov 24, 2004 12:30 AM
