Has anyone run 0 guage wire on XB
Old Aug 15, 2005 | 01:53 AM
jallamas's Avatar
Default Has anyone run 0 guage wire on XB
Has anyone run 0 gauge wire through the stock wire harness on the xb and was it hard too do? If not any suggestions?
Thanks
John
Old Aug 15, 2005 | 02:18 AM
chadfo's Avatar
I ran 2 guage but not through the stock harness. I think trying 0 will be a very tough if not impossible fit. I went to Partsexpress.com and bought a firewall bushing (Link below) to use so it would be secure. The two things that were most agravating was having to find a 7/8 inch drill bit (set me back ($40) and drilling the hole on the fender side of the factory hole so it would be hidden and not worry about damaging anything. Trust me it was a real pain in the rear but the results were worth the aggravation.
Here's a pic of mine. If you follow the wires from the circuit breakers on the right under the plexi, you can see they go under the cruise control and you can just see them behind it and then they vanish. It makes for a very clean look.
Here's a link to the correct size you'll need:
http://www.partsexpress.com/pe/showd...number=263-635
Old Aug 15, 2005 | 04:47 AM
jallamas's Avatar
chadfo,
Thanks for the info, how hard was it to drill the hole for this. For 0 gauge I think the bit is 11/2. Thanks for the parts express info.
John
Old Aug 15, 2005 | 08:28 PM
jallamas's Avatar
Ok, I was thinking that since so much power was going through the 4 gauge wire for 2 amps maybe I could run one 4 gauge wire for each amp instead of running 0 gauge to the battery. Will this still work?
Thanks
John
Old Aug 15, 2005 | 09:51 PM
chadfo's Avatar
It sure will if each amp doesn't require more than 4 ga. I'm pretty sure you can get 2 4 ga wires through the factory hole but not much else after that.
Old Aug 15, 2005 | 10:18 PM
chadfo's Avatar
Originally Posted by jallamas
chadfo,
John
It was just a pain because it's very tight back in there. You can put it somewhere else. I just wanted it as much out of the way as possible. There was nothing in the vicinty on the inside that I had to worry about damaging so I punched it through. You might have an easier time drilling from the inside. Had I know everything was so open under the dash that's what I'd have done. Here's a link to the writeup I did about how to remove the dash if you decide to go that route. It's actually quite easy.
https://www.scionlife.com/forums/vie...647&highlight=
Old Aug 15, 2005 | 10:29 PM
jallamas's Avatar
chadfo,
Thanks for the replies, I think I will try the 4 gauge route with 2 wires.
John
Old Aug 15, 2005 | 11:47 PM
Max2k's Avatar
My brother pushed 0 gauge through on his xB. It wasn't that hard, it just took a little patience and arm strength. 2 4 gauge would be easier, but you wouldn't get the same results.
Old Aug 16, 2005 | 12:25 AM
jallamas's Avatar
Max2k Could you tell me how he did it throught he wiring harness? Any help would be appreciated.
Thanks
John
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
FurionAlpha
Scion tC 1G ICE & Interior
Jan 12, 2015 08:25 PM
randode
44
Jun 29, 2004 04:19 PM
Docofmind
Oct 25, 2003 04:33 AM
vpkb
12
Oct 8, 2003 04:17 AM
