does the 02 sim work or not
Old Aug 22, 2005 | 06:25 PM
seminoles68's Avatar
Default does the 02 sim work or not
I have seen so many people post about this item i have trying to figure out if this thing works like zpi says it does or are they full of crap. I figured out that most people that posted about the nonfouler thing was either crazy or it works on only some tc's(strange). So the question is does it work with eliminating the cel of not.(o2 sim)
Old Aug 22, 2005 | 08:33 PM
ScionDad's Avatar
Default Re: does the 02 sim work or not
Well, I did the antifouler mod and it worked perfect and has for over 8000 miles now. My brother cautioned me that when I do it, make sure I use a 1/2" drill bit and make sure I open it up completely or it will not work right. For $3.00, it was kinda silly not to try it.
Old Aug 22, 2005 | 08:43 PM
robFMtC's Avatar
did you use two antifoulers and drill a hole in just one and not the other? or did you use two and drill holes in both? or just one with a hole drilled in it?
Hope that makes sense...
Old Aug 22, 2005 | 09:01 PM
ScionDad's Avatar
You will use 2 of them and drill a 1/2" hole in just one. When you buy them from any autoparts store, they come in a 2 pack.
The Scion thread of how to
https://www.scionlife.com/forums/viewtopic.php?t=49748
Here is a how to with pics
http://forums.evolutionm.net/printthread.php?t=99137
Old Aug 23, 2005 | 12:05 PM
when you use the nonfouler your ecm is not getting a correct reading for your o2 sensor because when you do that u pull it out of the pipe.
Old Aug 23, 2005 | 12:31 PM
robFMtC's Avatar
so what exactly are you saying? are you saying its bad to do this? or are you explaining how it works?
Old Aug 23, 2005 | 12:58 PM
ScionDad's Avatar
Any mod short of installing a first cat only tricks the ECU into thinking the first cat is there. This "trick" is only $3.00
Do the math
Old Aug 23, 2005 | 01:49 PM
I am stay that the 02 is not going to get an accurate reading with the nonfouler
Old Aug 23, 2005 | 03:29 PM
robFMtC's Avatar
Ok then why isn't there a CEL then? b/c that's what causes the CEL right? bad readings?
Its inaccurate b/c it is being fooled into thinking everything is fine... therefore an accurate reading would be that there is no Cat. and there is a 'problem" according to the o2 and then a CEL is appears on the instrument panel
hope that makes sense
Old Aug 23, 2005 | 04:41 PM
WeDriveScions's Avatar
I'm sending my sim back to ZPI for testing and diagnostics. I believe that we'll get it worked out and we'll all be back and running with no CEL's soon...
Old Aug 23, 2005 | 10:47 PM
mr_lore's Avatar
I'm so glad I got a working sim from nexus and waitied to install both the sim and the header at the same time. There are soo many posts about upsetting expierences with sims its insane. I've never seen the check engine light on my car, 5100 miles atm.
Old Aug 24, 2005 | 12:05 AM
zoltiz's Avatar
N.G.S.O.
I am stay that the O2 is not going to get an accurate reading with the nonfouler
Second 02 sensor is used *only* for emissions system of the ECU, so the "correctness" of the reading will not affect the car's performance in any way, as long as the CEL is not triggered.
First sensor, the air-fuel ratio sensor, is the important one, so it does not matter if you do the anti-fouler for the second sensor or the O2 sim - as long as it keeps the emissions system tricked - you will be ok.
Old Aug 24, 2005 | 02:16 PM
smash's Avatar
has anyone contacted Alphawerks about this issue? i've been driving around with the CEL on for quite a while now. James with Creative Compacts said he would contact me when he had a fix for it but I've yet to hear from him and doubt I will.. so .. my question is.. what would be the best way to go about getting this problem fixed? It's driving me nuts.
Old Oct 6, 2005 | 10:19 PM
toyota_scion_tc's Avatar
did you get the two 18mm anti fouler and screw them together? did you drill both of them?
xBSciontist
Jun 18, 2019 03:06 PM
missing_image
Feb 7, 2015 07:18 PM
cid_mcdp
Jan 5, 2015 02:45 PM
TheTripleC
Jan 4, 2015 06:46 PM
gettoastedinthetoaster
Scion xB 2nd-Gen Wheel & Tire
Dec 29, 2014 11:39 PM
