widest wheel/tire setup on an xb?
Old Sep 12, 2005 | 06:30 AM
peabe's Avatar
Default widest wheel/tire setup on an xb?
whats the widest set up that someone has or has heard of on an xb?
Old Sep 12, 2005 | 05:39 PM
tinybigrig's Avatar
biggest ive seen is 18x8.5 18x9.5 im not sure on offsets though
id assume in the area of a 30 or 35 in the front and maybe a 15 in the rear?!
brent
Old Sep 12, 2005 | 05:49 PM
stankubrick's Avatar
With or w/o camber? W/o camber, the widest I've seen is 9 in. It also depends on your drop and tire size. Now, with crazy camber (edit: and/or crazy fender mods ), you can go crazy wide.
Old Sep 12, 2005 | 09:20 PM
MyBoX's Avatar
There is no limit when it comes to wheel width !!! JDMP
Old Sep 12, 2005 | 10:39 PM
scion619's Avatar
just curious to know if a 18x8 wheel 40offset with a 215/40 with goldlines will fit my xb? and will it rub? im currently running 18x7.5 42 offset with the 215/40 and i only rub when my front wheels are fully turned.... any help will be greatly appreciated...
thanks
scion619
Old Sep 12, 2005 | 11:07 PM
berto's Avatar
I know that the Fabulous bB runs 18X8.5 in the front and 18x9.5 in the rear, with an 18mm offset.
thanks
scion619
I couldn't tell you if they would rub or not, but the 8" with 40mm offset will extend an extra 4mm closer to the struts and 8mm closer to the fender then over the 7.5 at 42mm.
Old Sep 13, 2005 | 05:17 AM
peabe's Avatar
ok doke. i planned on running 17x8.5 +25 in front and 17x9.5 +25 in the rear.
Old Sep 13, 2005 | 09:57 AM
hotbox05's Avatar
18x9.5 front and 18x11 rear.
vi3tb0i09
Sep 23, 2015 08:32 PM
Subaru86
Sep 14, 2015 12:51 PM
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
Sep 13, 2015 04:39 PM
dbg326
Aug 28, 2015 05:18 PM
Davyo
Jul 29, 2015 05:53 AM
