what are the symptoms for engine knocking?
Old Oct 12, 2005 | 01:44 AM
intakeonly's Avatar
Default what are the symptoms for engine knocking?
is it lag in throttle response that leads to poor acceleration?
like when you press on the gas the car would just make a sound but not go?
i think this is happening to me after i got my exhaust
Old Oct 12, 2005 | 02:34 AM
Joe_Dezod's Avatar
An exhaust should not be causing excessive knock. It's just a simple bolt on. Plus our cars have built in knock sensors that pull timing if it detects knock.
Knock will make a slightly audible tapping sound. Your car will lose power, and you will damage the motor. The remedy is higher octane gas, colder intake temps, and retarded ignition timing.
Try resetting your ECU (disconnect the ground for about 2 min with the door open). Then when you start the car let it idle for about 15 min before driving it. It'll help your ECU relearn the fuel curves with an exhaust on it.
cpsamad
Apr 16, 2015 05:20 AM
Moth
Apr 14, 2015 12:17 AM
D_Roke
Mar 31, 2015 05:37 PM
eric_m
79
Mar 17, 2013 12:21 AM
BlueBox
14
Jan 15, 2004 01:08 PM
