help me find the parking lights wire on a tC (big pic no 56k
Old Oct 14, 2005 | 07:41 PM
xnevergiveinx's Avatar
Default help me find the parking lights wire on a tC (big pic no 56k
hey ya, i just bought an alarm system from autoalarmpro.com i got the ca330, which is an alarm that uses the existing key remotes.
anyways, the wire from the alarm should be connected to the parking lights wire. it says that its in the top of the fuse panel, in a 30 pin harness, pin 29, a brown wire.
ok, i found the brown wire, in pin 29, i think, but it doesn't test as 12volts positive when i have the parking lights on. i also tried all the wires coming off of the switch at the steering wheel, with no luck.
heres a pic, point it out to me! thanks!
Old Oct 15, 2005 | 01:36 AM
oh come on, someone had to install an alarm by themseleves...don't be shy!
Old Oct 15, 2005 | 03:59 AM
ChicagosFinest's Avatar
OhioScions
brown doesn't sound right to me at this very moment.. i'll get back to you about it soon.
Old Oct 15, 2005 | 04:05 AM
OhioScions
The answer from my sources say that it is the brown wire located at the switch (what good are they?) Sorry I couldn't be anymore of a help, Good luck!
oh and are you on OhioScions.Com?
Old Oct 15, 2005 | 02:05 PM
yah, i'm on ohioscions, of course!
Old Jan 15, 2006 | 04:17 PM
Harmonic_tC's Avatar
just go to the parking brake, its easy, its the only wire that goes to it
Old Jan 15, 2006 | 05:07 PM
so i can connect a 12v + wire to the one on the parking brake? are you sure about that? usually the parking brake gets a ground signal
Old Jan 15, 2006 | 08:35 PM
Spr0ket's Avatar
Blue... no green! Ah, I'm so confused. Oh hey, look a cookie.
Old Jan 15, 2006 | 09:58 PM
not sure, you said that you are trying to hook up to the parking break wire right? If it the wrong voltage then use a realy to to make it work right
carid
Jan 8, 2015 11:33 AM
DenZinz
32
Feb 17, 2004 06:56 PM
racingtoys
Dec 4, 2003 10:34 PM
scioninla
14
Oct 18, 2003 03:46 AM
hatchbox
Oct 3, 2003 03:41 AM
