How do i disconnect the overdrive wire for an automatic
Old Oct 29, 2005 | 04:02 AM
dredge38's Avatar
Default How do i disconnect the overdrive wire for an automatic
Im doing some painting and want to paint that silver on my automatic ****, i can get it off but the wire is still connected. Also i havent looked yet but i also want to paint the silver tabs on the sides of the steering wheel. Do i just unscrew the two screws behind the steering wheel and pop off the cover. Thanks for any help
Old Oct 29, 2005 | 08:28 PM
dredge38's Avatar
bump hasnt anyone takin this apart?
Old Dec 31, 2005 | 05:17 PM
BigMllc's Avatar
hey how the hell did you get that silver thing off the shifter??? also, were you able to get the whole shifter off? i am trying to replace my shifter with an aftermarket one
Old Jan 2, 2006 | 05:41 AM
jayrod's Avatar
The silver accent can be removed from the shifter with a flat-head screwdriver and care. It pries right off, just be mindfull that the overdrive button is attached to the accent piece.
As you pull the accent free from the shifter, you'll notice that that a small circuit board is attached to it via small snap-tabls. Prying those away from the board will allow the accent piece to be removed. Also, you'll need to cut the small wire-tie that keeps the wiring connected to the accent piece for easy removal.
I hope this helps. It's been a while since I removed mine.
Old Jan 2, 2006 | 01:27 PM
BigMllc's Avatar
anyone know of an after market shifter for automatic i can use... i want one with an OD button, also i prefer not to cut any wires to install it!! THANKS
whiteboymills
Mar 14, 2015 08:10 PM
2006whitexb
Mar 11, 2015 12:39 AM
Scionxa180
Feb 17, 2015 05:35 PM
DerekMarq
Jan 27, 2015 02:38 PM
bbdude
Jan 15, 2004 02:42 AM
