headlight stays on no matter what
hi guys, know its my first post here but cannot find any answers.
My headlights stay on no matter what I tried, I pulled out all the relays that I can see, included under the hood by the battery and my headlights stay on.
I also switched the headlight switch, but still the same. Anyone else had this issue before?
It's getting impossible to drive at night, and then having to open the hood to manually disconnect the headlight wires
thanks so much in advance
The previous owner did some hokey wiring... If the headlights stay on no matter what, then that means they are wired to only a constantly hot wire, which would be one that hooked right to the battery. You need to follow the wires from your headlights to see where they are tied-in.
This problem just started happening, first it was sporadic so I unplugged the wire. Now its just a constant.
So there are no relays or anything that I can first check? Its hard to follow the wiring because they look OEM and bundled with many other wires
Go to this site and pull-up a schematic.
https://techinfo.toyota.com/techInfo.../Register.aspx
If you have any wiring mods, start with whose first.
Good luck
Good luck
mischman
Sep 15, 2015 03:38 PM
