Mr. Clean Auto Dry is great but..
Old Nov 11, 2005 | 04:34 PM
bluemoon's Avatar
Default Mr. Clean Auto Dry is great but..
I used Mr. Clean's Auto Dry Wash for the first time and love how shiny my car is even after our rain yesterday. The process is so easy. I love it. No drying necessary and no spots.
However, the connectors to the hose and spray gun leak! I came away soaked. I tried to put washers I already had around the house in them, but they didn't fit. Has anyone found washers that work, and still let the soap and filtered water flow? How do you get the connectors to not leak?
Old Nov 11, 2005 | 04:53 PM
miamibusta69's Avatar
Mine doesnt leak and i dont even put it on tight at all. mayb its the end of your hose?
Or return !
Old Nov 11, 2005 | 05:03 PM
grimace's Avatar
i have got the same thing, more than likely it's u'r hose. what you need to do is get some plumbers tape. It's this white silcone tape that you wrap around the threads where you connect the hose. did that this morning, worked great, only a little dribble, next time i'll just wrap it up even more!
Old Nov 11, 2005 | 05:04 PM
matt_a's Avatar
Default Re: Mr. Clean Auto Dry is great but..
Yes, but did you dry spot free?
Old Nov 11, 2005 | 09:55 PM
I bet he did. I do every time
Old Nov 12, 2005 | 10:09 AM
Banana_Boat's Avatar
What he said...
Jim
Old Nov 12, 2005 | 04:17 PM
Max's Avatar
Max
Question: are you using the pro series? If so, are you using the quick release that came with it? If the answer to both of those is yes, I recommend taking off the quick release and just screwing the Mr. Clean on like normal. I had the same problem. The quick release is junk.
Old Nov 14, 2005 | 07:09 PM
deager's Avatar
I have an original model and have been using it for over a year. I boought my own quick release at the home store. It is brass. The "male" end threads into the Mr Clean and the "female" end threads onto your hose. No leaks.
Old Nov 14, 2005 | 07:21 PM
jmiller20874's Avatar
I love the Mr Clean system. Got the Pro one and no leaks. I'll never go back to the old bucket method again.
Old Nov 14, 2005 | 07:45 PM
Ericvpellegrino's Avatar
I'm glad I don't have to mess with all that working at the dealership and all JK Mr. Clean works pretty well
Old Nov 15, 2005 | 05:42 PM
bluemoon's Avatar
I'll try this. Thanks. I'll also check into a brass fitting. AND the tape. Thanks everyone.
BTW, I can't believe how shiny my car still is!
Sadly, though, the paint is fragile. Not the same incredible paint as my other Camrys.
helloninja
Mar 19, 2018 04:50 AM
mischadoll
Mar 9, 2015 05:48 AM
yhwhdesign
Mar 7, 2015 02:01 AM
toyotaisme
Jan 10, 2015 10:24 PM
TheTripleC
Jan 4, 2015 06:46 PM
