tapping the cigarette lighter
Old Apr 11, 2004 | 08:45 PM
JDMbB's Avatar
Default tapping the cigarette lighter
does anyone know what color ,or, what wire is the power going into the cigarete lighter?? i want to hook up my interior lighting using the cigarette lighter to make it look cleaner. also, if i tap the neons to the cigarette lighter, do i have to ground it?
anyone???please help
Old Apr 12, 2004 | 03:46 AM
o4_USDM_bB's Avatar
if you pull the bottom piece out of the dash where the cigarette light is, you can actually see the two wires going into the cigarette lighter.
Old Apr 12, 2004 | 03:49 AM
JDMbB's Avatar
are the two wires different colors? casue i dont want to tap the wrong wire by accident. i need to tap the power wire.
Old Apr 12, 2004 | 03:52 AM
o4_USDM_bB's Avatar
electricity runs in a cycle. you can't just tap the "power wire" you need both the 12V+ and the ground. if you tap just one wire, it's not gonna do anything. use a multi-meter to test which is which...
Old Apr 12, 2004 | 03:57 AM
got_xA's Avatar
xA model:
green wire = positive
white wire = ground
PEACE
Old Apr 12, 2004 | 04:04 AM
JDMbB's Avatar
thanks for tellin me that. didint want to mess anything up. but since my neons have both a positive and negative wire, would i connect the negative wire from the neons to the negative from the cig lighter ?
Old Apr 12, 2004 | 04:26 AM
TheScionicMan's Avatar
You can do either. Tap the neg wire or ground it somewhere else. As long as the curcuit is completed, it's all good.
Old Apr 12, 2004 | 04:32 AM
JDMbB's Avatar
so your sayin that i connect the positive from neons to the positive on the relay, connect the power to the power on the relay, and then just connect both negative wires together and ground the relay ?
im sorry if im getting a little repetetive, i just dont want to mess up when im doin this.
Old May 28, 2004 | 06:30 PM
S3X's Avatar
S3X
Hello peeps... need help again.
Is this diagram okay if I want to tap into the CIGARETTE LIGHTER?
http://www.imagestation.com/album/?id=4286735699
Thanks for any help.....
Old May 28, 2004 | 07:01 PM
Minsk99's Avatar
You do not need to tap into the negative wire (ground) of the cig lighter. You can ground to any appropriate grounding point. I have tapped behind my lighter for gauges, digital compass, and mp3 player dc power source. I have not used the cig lighter ground for most of them and ran a ground directly to the chassis of the car. The location I like to use is a designated grounding point that is located right below the cockpit fuse box. You can use the cig lighter ground, but if it is more convenient to ground elsewhere it is no problem. A cheap and effective voltage tester can be had for like $5. This will let you know for sure which to tap into.
FYI, for the xB, the black wire with thin white stripe is positive wire and the white wire with thin black stripe is negative.
Old May 28, 2004 | 07:13 PM
DJ_SpaRky's Avatar
I almost didn't see that.
Old May 28, 2004 | 07:46 PM
Tamago's Avatar
you'd do better running a power source into the car from the battery
Old May 28, 2004 | 08:38 PM
Max2k's Avatar
You can just pull power off the battery, it's not that difficult.
Old May 30, 2004 | 05:27 PM
S3X's Avatar
S3X
SUCCESS!!!! hehe... Ey guys! I just wanna show my new mod... CD storage light with a switch....
http://www.imagestation.com/album/?id=4286717977
take note... the power that runs through the CIG LIGHTER only powers up when the key is on the ACC or ON position... so if you guys try to switch the lights on and the light doesn't come out, plug your key into the ignition and switch to ACC or ON....if the lights still doesn't come on... check the T-Taps (Scotchlock) if it really tapped the wire. I had a t-tap that clamps on wire sizes 14-18 and the first attempt, it didn't cut through the plastic cover of the wire so I thread the wire a littlebit and crimped the T-tap again.... then the problem was solved.
Alright folks! have a NICE Holiday!!!!
Old Jun 1, 2004 | 04:44 PM
Tamago's Avatar
i've added a suggestion on your imagestation..
SloTC1
Aug 16, 2018 02:45 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
ScionLife Editor
Sep 15, 2015 04:40 AM
StxArOne
Scion xA Aero & Exterior
Aug 29, 2015 03:29 PM
JonathonK
Aug 26, 2015 08:30 PM
