Satellite Radio Antenna Install in xB..
Old Nov 28, 2005 | 03:10 PM
largosama's Avatar
Default Satellite Radio Antenna Install in xB..
I just received the Sirius Sportster radio for my xB. I have it up and running and it sounds great! However, I need help with my antenna. Currently, I just open my window, slap the magnetic antenna to the roof and drive away.
That's fine for temporary purposes, but I'd like to get that antenna in a regular spot. I'm not going through the head unit to install. I'm running the Sportster through the cigarette lighter and running the antenna from the Sportster.
So, the question is, how the heck do I install the antenna? Ideally, I want to run this through the back hatch, run it under the seats and into the radio from there.
However, I'm not sure how to get the wire from the outside of the car to the inside unless I'm doing the 'roll down the windows' every time route.
Help me out!
_______
Old Nov 28, 2005 | 06:07 PM
DJ_SpaRky's Avatar
I'm going to be getting Siruis very soon, & have been researching this. Because you want it on the back hatch, you'll need to fish it under the carpet or down the door sill rail & then up the corner...... OR ....do what I want to do & mount it to the top of the dash, right behind the gauge cluster, near the defroster, then wire it down to the Tuner & away you go.
if you still need help by the time I get mine in, I'll take pics for everybody to see.
I think it'll work fine & look good, plus be a hellalot easier to wire/install.
Good luck with the install.
Old Nov 28, 2005 | 07:13 PM
metro's Avatar
I wired mine behind the dash (remove glovebox) then ran the wire under the door footplate cover thingy's all the way to the back then under the carpet, up the plastic trim to the top of the back hatch and then out the back hatch about 2 inches to the top of the roof
Old Nov 28, 2005 | 07:23 PM
largosama's Avatar
How do you get that wire out of the hatch? I don't want to shut the hatch constantly on the wire.
Old Nov 28, 2005 | 08:24 PM
a_dvs_1's Avatar
i would go with option number 2. i have xm in my suburban and getting it for the XB next week, and in 3 years i have never had problems with the antenna mounted inside the dash of my suburban. Just stick it in as far as you can and as close the top of the dash and window area. The less metal around it the better. The signal goes through most plastics and other things. the only problem is metal.
Old Nov 29, 2005 | 01:02 AM
violent_b's Avatar
I have my Sirius antenna on the top of the hatch and ran the wire through the grommet coming from the hatch. I've had it that way for 6-8 months now with no problems. I will be looking into hiding the antenna like in the front bumper or something for a cleaner look.
Old Nov 29, 2005 | 12:55 PM
DJ_SpaRky's Avatar
Hey, Bill, there is a nice big metal bar going from side to side in the front of the car, oh wait that the actual bumper, LOL.
I'm going to look into the dash Idea, or maybe on the outside of the A-Pillar.
anyways, largosama let us know if you get it installed.
Old Nov 29, 2005 | 11:15 PM
kmcniece's Avatar
I ran mine through the grommet where the water goes through to the rear window washer.... the wire never gets "shut" in any door that way. I have had no problems.
The factory suggests running it through, behind the rear tailight housing.... I found that to be quite a chore...
Old Dec 5, 2005 | 03:47 PM
DJ_SpaRky's Avatar
My Sat Radio install has been delayed, but I'm still going to try to install it on the dash, or maybe on the front bumper under the plastic. (Hint hint Bill)
Old Dec 5, 2005 | 04:48 PM
Max's Avatar
Max
I have mine mounted on the roof, just in front of the rear hatch. The wire goes between the hatch and the roof. Very clean and no issues in about 8 months.
Old Dec 5, 2005 | 07:20 PM
DJ_SpaRky's Avatar
The problems that I have with putting out side, is it moving. When it moves it will scratch the paint & leave marks, I also tend to drive fast (believe it or not) & don't want it to slide of the back or something.
I would love to find a Used xB Spoiler & mount one inside then Fiber glass over it & mad it look stock.
Old Dec 5, 2005 | 10:51 PM
kmcniece's Avatar
It shouldn't move, from general or aggresive driving. It is very strong, despite your driving style....
However, an aggressive automatic car wash will send it right off the car.....
Old Dec 6, 2005 | 12:32 PM
DJ_SpaRky's Avatar
OK, so 115mph winds ;) won't move it??
eww, auto-wash, I don't need to worry about that.
Old Dec 9, 2005 | 07:27 PM
DJ_SpaRky's Avatar
Well, Once I get it if I don't have it up on the dash & working fine, I'll prolly run it back & wire it up that ways.
anybody wanna sell a OEM Spoiler?? so I can modify it house the Antenna.
Old Dec 9, 2005 | 07:46 PM
Sciond's Avatar
I ran mine down the pillar next to the dash and under the rug by the door sills through to the back and under the weather stripping up to the roof line and out on the roof
Old Dec 20, 2005 | 07:13 PM
DJ_SpaRky's Avatar
I finally got my Sirius Tuner unit (SIR-ALP1) & got it installed, the antenna is on the Dash & it's working so far, I need to rerun it though, but I'll wait until 'violent b' does the bumper thing to see if it works, I'll probably do that.
Old Dec 21, 2005 | 03:12 PM
INSIDEOUT's Avatar
That is how I did mine!! If you put it inside you are most likely not going to get asgood as a signal as you would if you went outside!!
Old Dec 28, 2005 | 11:27 PM
psulion92's Avatar
Default Rear Antenna
Can someone be SPECIFIC on how to get the wire from the front of the car to the back? Pictures would be sweet!
JS
Old Dec 30, 2005 | 01:29 AM
DJ_SpaRky's Avatar
down the door jams, under the plastic pieces. Just pull up the plastic & you figure it out.
EvalEvan66
Jan 27, 2015 02:26 AM
EvalEvan66
Jan 16, 2015 08:34 PM
Nargrakhan
Scion iQ ICE & Interior
Dec 10, 2014 06:10 AM
crocker
Dec 2, 2014 03:44 AM
korbendalis
Oct 5, 2004 03:40 AM
