amp for 2 10s
Old Dec 7, 2005 | 01:56 PM
tieccDOTnet's Avatar
Default amp for 2 10s
i have 2 power acoustik fubr 10s and i am planning on getting a kicker amp... about to go shopping so ill post the specs when i get back unless someone already does... i am looking to spend 2-300 for the amp... the subs are dual voice coil but i am not sure ohms... what kinda amp or amps should i use? thanks guys
Old Dec 7, 2005 | 02:40 PM
mandos's Avatar
Weel, it really depends on the VC's on the subs which amp you should go for.
Until we know that, kinda hard to say.
Old Dec 7, 2005 | 05:03 PM
they are dual 2ohm and 600 watts rms and 1800 watts max... power acoustik speakers are good, but their amps... well just say the most expensive pa amp is like 150-200... had 2 **** 15's in my buddys truck and it was insane! he used 2 audiobahn flame amps tho... thanks guys
Old Dec 7, 2005 | 06:30 PM
mandos's Avatar
Hmm...2 ohm final load.
If you can find one, a Tsunami dB1800T...I had one for a bit over a year, worked great for me...took it out when I moved down to eD
Nine.1 would get you 8~900W RMS @ 2 ohms depending on what kind of voltage went into it, $315 with the SL forum discount.
I think this would be decent for cheap power. A lot of people run them, somewhat over rated though in their output.
Old Dec 7, 2005 | 06:38 PM
kicker makes a 600w mono and a 400w 4chenel... i could bridge the 4 ch amp to one speaker and get 2 amps or i could just split the power from the 600w amp... what u guys think?
Old Dec 7, 2005 | 06:55 PM
mandos's Avatar
Well, the subs handle 600W RMS each. If that's an accurate rating, I'd suggest looking for 1 mono block amp that does around 1kW at 2 ohms. The Nine.1 and the HiFonics mentioned above both do this.
If you wanted to go with Kicker, a pair of KX600.1's would be your best bet for this.
Old Dec 7, 2005 | 07:05 PM
ok well for now i just want eather 2 400w or 1 600w. i would guess that the 2 400w 4ch would be best since it is dual voice coil... correct?
Old Dec 7, 2005 | 07:34 PM
mandos's Avatar
If you're set on either 1 600W mono or 2 400W 4 channel amps, get the 1 600W mono amp. You probably won't notice a difference in output and it'll save you an insane headache in wiring.
Old Dec 7, 2005 | 07:44 PM
SCI_TC_GUY's Avatar
the number of VC's doesn't have any bearing on how many channels you have....
If you're set on getting 2 amps, get 2 that are 500 or 600 watts MONO at 1ohm stable..... this will give you 500-600 per sub... You'll be able to take each sub and wire the VC's together in parallel making 1ohm per sub.
If you want to just have one amp (best bet IMO) get a MONO 1000-1200 watt 2ohm stable amp.... You'll be able to take each sub, wire them both in series independently (making each sub a single 4ohm load) then wire the 2 subs in parallel to make a 2ohm load total...
Old Dec 7, 2005 | 10:16 PM
wow... can you make up a diagram for that... thanks
Old Dec 7, 2005 | 10:27 PM
mandos's Avatar
Like that?
Old Dec 8, 2005 | 11:09 AM
SCI_TC_GUY's Avatar
^^ that will be good if you have an amp that is 1000-1200 RMS watts @ 2ohm mono.... If you want 2 seperate amps, then you'll wire each amp to each sub like this:
that will give you a 1ohm load at each amp....this means each amp will need to be 500-600 RMS watts @ 1ohm mono
Old Dec 8, 2005 | 11:32 AM
how would i wire a 1200w mono to both speakers cuz thats what i ordered... remember they are dual 2 ohm voice coils... thanks guys
Old Dec 8, 2005 | 11:35 AM
SCI_TC_GUY's Avatar
It needs to be 1200 watts mono @ 2ohms
you'd wire it like this:
prescottn
Scion tC 2G ICE & Interior
Apr 26, 2016 01:14 AM
DannyBoy65
Sep 21, 2015 06:23 PM
crimson10tC
Sep 10, 2015 08:44 PM
volume315
Aug 29, 2015 01:31 PM
volume315
Aug 29, 2015 10:28 AM
