tire pressure indicator
Old Dec 7, 2005 | 03:00 PM
schwettynuts's Avatar
Default tire pressure indicator
Can someone explain to me how the thing works? Where is the sensor? When I did tire rotation it gave me false alarm. When I changed the rims and put new winter tires it gives me false alarm almost daily. Any comments?
Old Dec 7, 2005 | 03:10 PM
imsonofagun's Avatar
It isn't an actual pressure sensor. It senses wheel rotation. In theory, a punctured tire rotates faster than the other tires. The sensors can get confused if you make changes without resetting them. According to the manual, you're supposed to drive around for an hour after hitting the reset button. It's an OK system, but has it's flaws.
Old Dec 7, 2005 | 03:30 PM
I reset it 3x already and drive around alot after reset. maybe because its snowing hard so it is confused? Oh well, I just think its annoying.
Old Dec 7, 2005 | 04:01 PM
Keith's Avatar
Where is the RESET BUTTON ????
Thanks....
Keith.
Old Dec 7, 2005 | 04:16 PM
Wide_tC's Avatar
The button is in the glove box.
Old Dec 7, 2005 | 04:22 PM
foreverandaminute's Avatar
It keeps coming on during driving in the rain... ha.
Old Dec 7, 2005 | 04:32 PM
Can always try Duct Tape...
I dunno. I haven't had any problems with mine. I'd recommend taking it to the dealer, but those guys take forever to do anything.
Old Dec 7, 2005 | 06:09 PM
WeDriveScions's Avatar
Mine comes on sometimes and is ALWAYS right... I carry a good tire pressure guage and one of my tires is always off a bit when it comes on...
I have all my tires at 41 PSI and it works well for me...
I'd check to make sure all your pressures are IDENTICAL, as that's usually the cause...
Old Dec 8, 2005 | 12:44 AM
Anyone try filling the tires with Nitrogen instead of regular air? It's supposed to keep the pressure constant and it won't leak like regular air since the molecules are bigger.
Old Dec 8, 2005 | 05:08 AM
Streeter's Avatar
It's worked great for me - I've had two tires that picked up nails on seperate occasions and it's always came on. They were slow leaks and they always would come on when the tire pressure went low.
Old Dec 8, 2005 | 05:38 AM
I wonder where I can fill up with nitrogen... sounds like a good solution....
If anyone knows... I'd be possibly interested
Old Dec 8, 2005 | 10:50 AM
2_tC's Avatar
I believe costco has nitrogen. America's Tire filled mine with nitrogen when I got wheels there.
Old Dec 8, 2005 | 12:19 PM
dazzler's Avatar
corvettes have a sensor inside the wheel that senences the actual pressure
Old Dec 8, 2005 | 12:36 PM
Limey's Avatar
*golf clap
Old Dec 8, 2005 | 01:17 PM
cmlloveless's Avatar
My sensor was tripped alot because my suspension was loose! I got it torqued and the sensor has not gone off since.
Old Dec 8, 2005 | 01:44 PM
So do the RX-8s
Old Dec 13, 2005 | 11:46 PM
fivepointnine's Avatar
mine has been tripping the past couple days, I think one of my tires is a pound or 2 different from the others...I hope....
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
kingofthecrate
Jan 21, 2015 09:28 PM
JDMxB
23
Feb 26, 2004 06:16 AM
Strader
Oct 12, 2003 11:46 PM
