Thoese with DDX 7015, PLEASE READ!!!
Old Dec 19, 2005 | 05:41 AM
TheGreatTonge's Avatar
Default Thoese with DDX 7015, PLEASE READ!!!
Hey guys hows it going. I ordered the DDX 7015 and also got the spacers model # 86221-52060 and 86221-52050. Ive read some installs so I know I can use the stock brace to hold it in, just gotta drill some holes to make it fit. Couple of questions...
1)where did you get the wiring harness for the unit?
2)How did you mount the spacers, did ta glue em in or something?
3) How did you modify the the unit to play while your car is driving?
THanks alot!
Old Dec 19, 2005 | 05:43 AM
dp-_-'s Avatar
wth are these?
Old Dec 19, 2005 | 05:00 PM
BUMP!!
Old Dec 19, 2005 | 06:48 PM
ricexizxgood's Avatar
Well I got a AVIC-D1, but the wire harness should be the same. I used this one:
http://www.cardomain.com/item/SCOTA02B
Old Dec 22, 2005 | 06:01 PM
freeflowing's Avatar
tie the yellow wire to goung i believe
the spacers from what i remember just screw in on the sides
its the wire harness form a 85 toyota celica or camry or xb. metra harness. check car domain and pick the harness up at walmart
Old Dec 24, 2005 | 06:18 AM
afex505's Avatar
since its a jap car and the ddx is a standard double din, the screw holes will line up perfectly. However, the radio door does not shut this way - i just redrilled the screw holes on the existing metal brackets, works fine. pics are in this thread:
https://www.scionlife.com/forums/viewtopic.php?t=98231
Old Jan 12, 2006 | 01:05 AM
etsnet's Avatar
Default Re: Thoese with DDX 7015, PLEASE READ!!!
Where can I get these spacers? Can I get them at a walmart or something or some place online? Thanks!
Old Jan 13, 2006 | 01:38 AM
yamaha16bw's Avatar
No those spacers are only through your toyota dealer. They are from a celica I believe. I used 3M black foam tape to mount mine.
Old Jan 13, 2006 | 04:24 AM
krdshrk's Avatar
If I go to a toyota/scion dealer and ask for them, will they know what I'm talking about? Are the 86221-52060 and 86221-52050 part numbers valid?
Old Jan 13, 2006 | 03:23 PM
yamaha16bw's Avatar
Yes they will know. I emailed Ken from TRDSparks.com and gave him the part #'s and he got them for me for only a couple of bucks.
Old Jan 13, 2006 | 08:12 PM
krdshrk's Avatar
Sweet. Thanks!
Old Jan 13, 2006 | 10:12 PM
etsnet's Avatar
THANKS!
Old Jan 13, 2006 | 11:08 PM
BrEaK_AwaY's Avatar
are the spacers needed? what exactly do they do? all the the bracket that holds the unit in?
Old Jan 14, 2006 | 12:21 AM
jetlounge's Avatar
spacers are used for trim, makes the install look more finished.
Old Jan 30, 2006 | 12:53 AM
backjackII's Avatar
Did anyone manage to install the 86221-52050/86221-52060 with the avic-d1 and the bracket mod (drilling)? I can't seem to find the holes needed to put mount the dash kit. THe bracket also seems to be obstructing the dash kit. Any ideas?
DougC
Feb 22, 2015 02:39 PM
stayintrucha
Scion tC 2G ICE & Interior
Dec 18, 2014 04:36 PM
lunchbx05
Dec 11, 2014 06:13 PM
NJthunder5spd
Mar 17, 2004 08:38 PM
Jester
Mar 2, 2004 04:52 AM
