Installing tweeters in the defrosters?
Old Dec 21, 2005 | 02:03 PM
jcook's Avatar
Default Installing tweeters in the defrosters?
I plan to install my tweeters in the defrosters on the dash. they are the same size as the hole. I just need to remove a little material inside the hole to make them fit. My question is, what is the best way to run the wire throught the dash? If i drill straight down into the dash what will i find? Help me out. thanks in advance.
Old Dec 21, 2005 | 02:49 PM
mandos's Avatar
Any reason that you aren't using the stock location? I mean...putting them in the defrost, you'll have to plug the vents up before getting to the tweeters...exposing them to constant heat wouldn't be the best idea.
Honestly... I have no clue where you'd run wires in the dash...I'd be very careful about just randomly drilling...
Old Dec 21, 2005 | 02:55 PM
SCI_TC_GUY's Avatar
I could see using them if you were going to fiberglass an aimed enclosure for them in the defrost vents....but other than that, +1 to Mandos
Old Dec 21, 2005 | 03:15 PM
jcook's Avatar
my tweeters are two big for factory location. They fit in the dash. I never use the heat in the defrosters. i live in florida.
I hope this helps.
Old Dec 21, 2005 | 03:30 PM
SCI_TC_GUY's Avatar
I would probably try the sail panels before the defrosters.... what tweeters do you have?
SuBSiN
Mar 13, 2015 04:02 AM
CPL_Radar
Mar 5, 2015 05:42 AM
Frustratez
Feb 26, 2015 04:03 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
iglooxb
Nov 6, 2003 05:42 AM
