Question to those of you who have Sirius satellite Radio.
Old Dec 27, 2005 | 12:42 AM
Banana03's Avatar
Default Question to those of you who have Sirius satellite Radio.
If you have Sirius radio in your car, how is the sound quality? I just got it installed this morning in my Scion TC and I'm really disappointed in the sound quality. There is no static, the reception is fine except for it getting the occasional no signal sign. But the sound quality is like I'm listening to songs on AM radio. I am getting better sounding music out of my FM radio then my satellite. It is not even close to the CD quality that they advertise it as. Is this normal or is it possible that the dealer wired it wrong?
Old Dec 27, 2005 | 01:07 AM
stl_tc_king's Avatar
i have it, but i have a seperate unit and it is modulated to an FM station. needless to say SQ is lost. I wish it sounded a little better, but i still love it!
Old Dec 27, 2005 | 02:30 AM
WeDriveScions's Avatar
Sattelite radio is similar to MP3 quality... If you run a FM modulator... it's that much worse... the best option is to connect directly to the aux in on the stereo...
It's not super high quality though....
Old Dec 27, 2005 | 02:55 AM
Banana03's Avatar
I am running it directly. Got the antenna and what not, and then the dealer hooked it up to the stock headunit in the TC.
Old Dec 27, 2005 | 03:47 AM
XB_BOY_2005's Avatar
Mine sounds dope, i dont have a stock HU tho, and i use the fm modulator
Old Dec 27, 2005 | 02:59 PM
ShaolinSuckerPunch's Avatar
I have the TOY03 Aux input.
The Aux input connects to the disc-changer plug in the back of the stock headunit. Then from my ipod & Sirius radio, I have a mini-jack (headphone jack)-to-RCA cable.
The Sirius radio, as far as sound quality, is not so hot really. You can't blame the stereo or the connections, because I also have an ipod hooked up through the TOYO03 and it sounds terrific. The Sirius radio I got (Xact Replay) sounds muffled. But it's MORE noticeable on talk radio than music channels.
I'm thinking the quality of the radio is not about reception, but about what brand receiver you buy. I got one of the cheapest Sirius radios, so I think that's a direct correlation. I have 0% problems with reception.
But I got my Sirius for Howard Stern, so I could care less about music-sound quality. As long as I can hear Howard!
Old Dec 27, 2005 | 03:40 PM
INSIDEOUT's Avatar
I have it and it sounds great
Old Dec 27, 2005 | 08:47 PM
JocoJef's Avatar
you should be getting near CD quality with it...I'd bring it back and tell them to fix it. You should be amazed with how clear it is. Where did they mount the atenna?
Old Dec 28, 2005 | 12:55 PM
My antenna is actually above the driver's side door.
Again, I have to point out though: It's not reception or interference, it's the muffled quality. Almost as if the radio has a low volume output (and yes, the volume on the sat radio itself is turned all the way up). Even if I turn the volume up louder on my headunit, it still sounds low on treble. So it sounds GOOD, it just sounds low. I feel this is just the quality of the Sirius radio I have, not about set-up. It would be nice if my Sirius unit had it's own EQ I could adjust.
If it was a problem with the TOY03, then my ipod would sound like ____e too, but it doesn't. It sounds perfect.
12" Custom Fiberglass Box with Rockford HE Sub
600 Watt Rockford Amp
Kenwood Headunit
Sirius Custom S-50 install
lol. With that kind of power your Sirius is running through, I doubt you'd notice if there was a quality difference! Even then, you probably have a more capable EQ on the Kenwood than a stock unit, and could probably compensate by adjusting. Try this next time: Keep your audio at one setting, then switch from Howard 100 to a music station, then to RAW DOG Comedy Channel. You'll notice the volume differences.
Old Dec 28, 2005 | 01:01 PM
JocoJef's Avatar
This may sound silly but what about your stereo settings? Are you working through a FM transmitter?
Old Dec 28, 2005 | 01:33 PM
Oh, for sure man! That's not silly by the way, sometimes people have problems and it's something so simple.
I got a mini-jack to AUX input cable from the Sirius unit to a TOY03 box.
I know all about the different settings (xa, xb, and tc) and what not. I've got my headunit on the xA setting, with the treble and bass maxed out to 5, all the speakers are equal.
I'm not bothered by it at all. Like I said, this is a much cheaper Sirius radio that you get at Target. Eventually I'll get one like yours, that doubles as a recorder, but for something I got from my friends for Christmas, I'm not complaining at all. I'm just happy I get to hear Stern when he debuts on 01/09/06!!!
Old Dec 28, 2005 | 02:04 PM
JLTD's Avatar
As both XM and Sirius increase channels without extra bandwidth the SQ is lost due to greater compression. Sirius is playing around with video now so it's only getting worse. I listen to my iPod 90% of the time and only listen to Sirius for talk radio.
Old Dec 28, 2005 | 02:22 PM
mattssi's Avatar
My sound quality in the car is much worse than in the home. It seems to get worse. I remember when I had it first connected it sounded awesome (I thought). However that was on a very nice custom audio system.
Sirius is the only satellite provider to have adaptive bandwidth (not sure if thats the term) so that more bandwidth is available to stations that need it, etc. I don't think they are going to sacrifice *much* quality for quantity or video.
That video is going to rock - peace up to XM.
Old Dec 29, 2005 | 08:19 AM
Shogun's Avatar
I have Sirius set up in my cavalier. I have a Panasonic head-unit that is directly connected and it sounds great. To match the volume of CD I have to turn it up, maybe, 2-3 notches (out of 40). The same goes when I use my iPod in the AUX input so its good.
Check everything, I like the quality.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
