Dash noises / vibrations / resonance with SC
Old Jan 8, 2006 | 04:52 PM
zoltiz's Avatar
N.G.S.O.
Default Dash noises / vibrations / resonance with SC
First thing I noticed after getting the SC in October was a whole new set of buzzing noises coming from the dash at various RPMs. Had the dealer take a look at it - the guys spent 2 days soundproofing anything they could find, but now, almost 3 months later I still have a buzz at 4500rpm that I tried to fix last night - pulled the dash out, dynomatted couple of suspicious spots, drove the car - seemed to be ok, but when I put everything *completely* back together - center console and such, the buzz came back.
I'm going to keep working on it, but was wondering if anyone else has the annoying new noises that appeared after the SC install. And I'm not talking about the "semi-truck style" whirring noise when you are coasting on the parking lot...
And a little scary picture from last night:
Old Jan 8, 2006 | 07:16 PM
Simplyscion's Avatar
Team No Limitz
I get the same dash buzz at around 3000-3300 RPMs, its really annoying...it seems that the sound is getting amplified coming through the drivers side front vent. It definitely drives me crazy at highway speeds
Old Jan 8, 2006 | 07:31 PM
terra_tC's Avatar
looks like a nightmare, sorry
Old Jan 8, 2006 | 07:47 PM
tikbhoy's Avatar
same here i thought it was something electrical related to the speed governor because i only hear it when i hit around 100+ Next time il pay more attention to it but its bearable to me.
Old Jan 8, 2006 | 08:32 PM
DTRUONG_112's Avatar
wow, you tore that dash up. Is it really that annoying, like will the music drown it out cause I got the SC on order, but if it is, I think I can bear it for the results that comes with the SC.
Old Jan 8, 2006 | 08:36 PM
zoltiz's Avatar
N.G.S.O.
The dash takes about 15 minutes to pull out if you know what you are doing. And about 30 minutes in my case.
The noise (now) is bearable, but still annoying.
Old Jan 9, 2006 | 01:32 AM
JT_Scion's Avatar
Yea, i get the same noise, but only if after accelerating and letting off the gas while without pushing in the clutch. But yea, it sounds like its coming from the around the driver side AC vent.
Old Jan 9, 2006 | 03:34 AM
ryno379's Avatar
Ditto
Old Jan 9, 2006 | 05:23 AM
zoltiz's Avatar
N.G.S.O.
Looks like a lot of people are getting these noises. These are not normal noises that are mentioned in the SC disclaimer. They have to be fixed by dealers or Toyco needs to get a TSB out and give the dealers some sort of guidlines as to fighting these noises.
Old Jan 11, 2006 | 05:52 AM
zachman's Avatar
Strictly Scionized
Yep, same problem really for me too. Vibration coming from under the dash, right by the gas pedal...I happened to rest my foot against a piece of plastic that was vibrating, which actually muffled the vibration - looking to see if the dealership will muffle the noise for me permanently. Vibration occures 3500-3800 rpms, around 80-85 mph.
Old Jan 12, 2006 | 06:31 PM
Nu_ERA's Avatar
ScionERA
Yea I hear the sound as well. Now that I have the ZPI boost pulley its pretty loud at 4000-4500 rpm. I have a sound system so I hardly hear it. I can see how it is annoying but I got used to it so it doesn't both me anymore.
Old Jan 13, 2006 | 12:33 AM
Garage1217's Avatar
The sound comes from a plastic panel right next to your gas pedal. Rev your car up to around 4K and listen, put your hand on the panel and it will go away Mine did it and it drove me nuts. Finally found it when I had some spare time. I pulled on it and part of a clip holding it broke and now there is no sound!!!!
Old Jan 13, 2006 | 12:34 AM
Garage1217's Avatar
Doh! Beat me to the answer. Yes that is the nasty panel.
Old Jul 6, 2006 | 09:34 PM
BOOBOY's Avatar
I just got my S/C intalled and same problem, so just take off the plastic panel right next to the gas pedal and the vibrating noise will go away.
Old Jul 6, 2006 | 10:04 PM
PghtC's Avatar
funny...I have never noticed this noise...and I do have the s/c. All I hear is the sunroof creaking away.
Old Jul 6, 2006 | 11:07 PM
jwaggz82's Avatar
yea - so do i.
Old Jul 7, 2006 | 01:05 AM
PghtC's Avatar
yeah and I am putting on my TRD Springs and struts this weekend so it can only get worse.
Maybe then the dealer will hear it and fix it. They told me no problem found...they didn't hear it.
Old Jul 7, 2006 | 01:08 AM
jwaggz82's Avatar
if i could do it over I would have gotten a .9 drop and that difference in 1/2inch might have helped my roof creak.
gedster314
14
Nov 17, 2018 02:56 PM
kmouse64
Sep 4, 2015 01:11 PM
Marialzga
Jul 31, 2015 05:38 PM
StxArOne
Jul 13, 2015 06:25 PM
TinmanTC
Jul 12, 2015 07:53 PM
