Knocking and Grinding coming out of l/f strut
Old Jan 9, 2006 | 10:51 PM
LED-Maniac's Avatar
Default Knocking and Grinding coming out of l/f strut
In the morning....when its cold....40ish.....whenever i drive over bumps, my front left strut makes an annoying knocking and grinding sound. Though both wheels are going over the same crack/dip/curb.....only my front left makes this noise. It feels like its "disconnected" and if there was soemthing loose. A visual inspection doesnt reveal any leaking fluids or any other obvious things. I rigorously checked the ball joints on both sides...which are both super tight.
Anyone familiar with the symptoms a strut will make when its on its way out.....this tc has about 30,000 miles one it .......this should be pretty early for a strut to go, but heck.....it CAN happen! any help would be appreciated!
P.S. this isnt just a sound..but a noticable jolt in the strut.
Old Jan 9, 2006 | 11:30 PM
The_Instigator's Avatar
Do you have any aftermarket shocks/springs? Are you running a strut brace? The upper mounting nuts may be loose..maybe they didnt get tightened enough when the new springs were installed or when a strut brace was added.
Old Jan 9, 2006 | 11:42 PM
LED-Maniac's Avatar
I wish I had springs! The car is completely OEM....lol
Old Mar 21, 2007 | 10:39 PM
smakusdod's Avatar
Did this ever get figured out? i experience the same thing...
Old Mar 21, 2007 | 11:27 PM
Otocan's Avatar
tighten the upper strut bolts, if you don't have a strut bar, it should be about 39ft/lbs, if you do, it should be bumped up to around 43-45ft/lbs, but it's just metal-to-metal bolts so the torque isn't critical, just make sure it's tight.
Renike
Mar 1, 2015 10:40 PM
greddy05tc
Feb 20, 2015 02:16 AM
hampton1100
Jan 2, 2015 08:13 PM
minter66
Dec 15, 2014 01:45 PM
randode
10
Dec 11, 2003 06:05 PM
