Cathode lighting install question
Old Jan 10, 2006 | 04:31 AM
Jowie's Avatar
Default Cathode lighting install question
I just got in my cathodes from oznium.com and their SPDT switch that fits into the knockouts on the dash. Now, why the SPDT(single pole double throw, aka on-off-on) switch? I want to have one side of the switch to turn the cathodes on when the domes are on, then the second to be on when I switch it to that postion. Kinda like the dome lights in the car have the door, off, and on positions. So the question, anyone know of a location in the fusebox that I can tap that triggers when the domes are on? I saw the following post:
https://www.scionlife.com/forums/viewtopic.php?t=100534
Would I use the "All Door Trigger"? I'm kinda confused cause it says the polarity of that is negative. So I don't know if that would work for me, as I THINK I need a positive trigger for the cathodes. Hrmm... Also, if I use that trigger, would the cathodes come on when I unlock the car like the domes do, or will they only come on with the door open?
Thanks!
Old Jan 11, 2006 | 10:06 PM
Jowie's Avatar
BUMP
Anyone?
Old Jan 12, 2006 | 04:18 AM
loOoFenixTxoOol's Avatar
i was thinking about this on the 9th when you posted it. still havnt thought of anything. im trying but not luck so far.
Old Oct 16, 2006 | 01:23 AM
mplex2000's Avatar
Dunno if you ever got a response but you could use a relay with the trigger connected to the door's neg to pass pos from battery to your lights.
TotalChaos
13
Feb 4, 2015 10:24 PM
Beesh
Jan 9, 2015 06:30 PM
randode
44
Jun 29, 2004 04:19 PM
randode
15
Oct 31, 2003 09:50 PM
BlueBox
9
Sep 25, 2003 04:36 PM
