Anyone try this one from Ebay...
Old Jan 12, 2006 | 02:28 AM
joffficer's Avatar
Default Anyone try this one from Ebay...
anyone try this one:
http://cgi.ebay.com/ebaymotors/04-06...28066318QQrdZ1
Old Jan 12, 2006 | 02:34 AM
Max's Avatar
Max
$60 shipped... Couldn't hurt.
X_treme_B's Avatar
I have the same model on my Xb except that it is a short ram , and I got 5hp increase ,it fit great, but no directions so make sure you know what u r doing overall I really liked it .
Old Jan 12, 2006 | 01:06 PM
Rocket's Avatar
I would Go With The YDR.
Old Jan 12, 2006 | 01:50 PM
smokeydog001's Avatar
I dunno, but its the first one I've seen advertised for the '06 models. I'm getting impatient waiting for some of the better known brands. This might be an option for me. Thanks
Old Jan 12, 2006 | 02:15 PM
CLEANTC's Avatar
I HAVE THE INJEN SHORTRAM ON MY TC AND BOUGHT MY GIRLFRIEND THIS ONE.. IT WORKS PERFECT..
Old Jan 12, 2006 | 02:55 PM
MexBox's Avatar
"I would Go With The YDR."
I second that!
Old Jan 14, 2006 | 10:24 PM
masafina's Avatar
I have that in my xb and works perfect for me
Old Jan 14, 2006 | 11:02 PM
jallamas's Avatar
YDR
Old Jan 15, 2006 | 01:00 AM
masafina's Avatar
Old Jan 18, 2006 | 12:07 PM
MikeC's Avatar
Did you have a problem with the coupler not eing the correct size for the tubing that connects to the throttle body?
Old Jan 18, 2006 | 08:58 PM
masafina's Avatar
MikeC Posted: Wed Jan 18, 2006 6:07 am Post subject:
yeah but when you put the ring they fit and for th e breather use soap
Old Jan 19, 2006 | 12:39 AM
joffficer's Avatar
what is the benefit of the longer tubing? Isn't it more metal to heat soak, and warm the air entering the engine?
Old Jan 19, 2006 | 01:33 AM
tyrantcold's Avatar
i got like the same one but from scion fx, the big long tobe with the bend is supposed to create induction force/torque , well thats what a freind of mine that tunes BMW's told me
Old Jan 19, 2006 | 03:01 AM
djct_watt's Avatar
Team Sushi
No. . . it's to go from a short ram to a cold air intake. One draws colder air, which is denser, which means more power. The other has less restriction, which means free-er flowing, which usually means more power, but in this case means hotter, but less chance of sucking in water.
Search for CAI and short ram. . . this topic has been extensively covered.
Old Jan 19, 2006 | 03:02 AM
joffficer's Avatar
masafina, did yours come with directions? How long did it take to get to you? How much did you have to remove to get this to fit (ie. Bumper cover, wheel well liner, etc)? Is the filter any good? Thanks, Jeff
Old Jan 19, 2006 | 06:26 AM
BCBrett's Avatar
I got an e-bay short ram intake a few weeks ago. I cant say that im disapointed at at all. for 50 bucks shipped it is a great deal especially when compared to the real thing. My opinion is there is very little diffrence between this and the real thing except the price. sure the directions suck, but it took me only an hour to install. I had to tweak one bracket a bit but id probably have to do that on a name brand one. When i looked into the CAI vs the short ram, i saw that all the tubing and bends in th cai just to get the air filter 6 inches lower. The way i see it the short ram gets the intake far enough out of the engine compartment, has way less bends and tubing, and saves me $$ for the next thing i want to put in my XB.
Old Jan 19, 2006 | 07:25 AM
OdBox's Avatar
You're right. i had to do that with my Injen CAI.
Old Jan 19, 2006 | 07:57 AM
djct_watt's Avatar
Team Sushi
You might want to look into that. . . but I know the design on this one is different than the injen one. The higher you go, the hotter it gets. . . and the lower and farther you can get from the engine, the better. If the bends are smooth, then even a few degrees of difference will overcome the flow change. Buy you can't really calculate it out easily. . . you'd need some extreme tests. . . or better yet and more simple. . . a dyno.
And the butt dyno is a very crude and inaccurate tool. In the long run, if the distances aren't huge, then the safety of keeping the intake far from water will be substantial. I strongly recommend that you do some research.
Old Jan 19, 2006 | 05:01 PM
RTon20s's Avatar
I didn't have any issues whatsoever with my Fujita F5. Great instructions and it installed exactly as they said it would.
It might cost quite a bit more, but in my opinion it is worth it. The position of the MAF sensor is better relative to the oil line, you get better hoses, better clamps, and extra filter, a duffle bag and a hat. For the price, it is really hard to beat their intake. If you can afford the price difference and the items listed above interest you, I would take a serious look at Fujita.
