Anyone try this one from Ebay...
Old Jan 19, 2006 | 09:55 PM
masafina's Avatar
joffficer Posted: Wed Jan 18, 2006 9:02 pm Post subject:
masafina, did yours come with directions? How long did it take to get to you? How much did you have to remove to get this to fit (ie. Bumper cover, wheel well liner, etc)? Is the filter any good? Thanks, Jeff
nop they not come with instructions but is realy easy to install and the only
I remove is the batery just that but for the price is a bang for the buck
just my opinion
Old Jan 30, 2006 | 04:29 PM
DoggyStyle's Avatar
Just installed this same setup yesterday. No direction but it was fairly easy to figure out. Not too thrilled with the cone air filter that was included, mine fell apart from the cheap glue used to assemble by the factory. I planned on upgrading the cone anyway. I just mixed up some 2 part epoxy and reattached the filter material to the metal base.
Old Feb 28, 2006 | 10:39 PM
BCBrett's Avatar
well i think i opted for the short ram for a few reasons, most of them not really based on research. the short ram was cheaper. It was easier to install, it was soo close to where the cai sat that those 2 things were almost enough. then i remembered my friends 3 month old caddy with a cracked engine block (nice new "northstar" one at the time). and that did it for me, keep that air intake out of the water, ill settle for a little bit higher and closer to the engine. that was my research, not too scientific, but then again what more am i going to get out of the half an engine they decided to put in my box =)
Old Mar 2, 2006 | 09:16 PM
joffficer's Avatar
I ended up with the short ram also. I bought the one from a guy here on Scionlife. Very nice for the money, and nothing but good things said (and to say) about product, shipping, etc
Old Mar 2, 2006 | 09:20 PM
outtaMYbox's Avatar
I have the ydr on my 06 box and i love it. easy instructions on the tech section here. Took less than 30 mins to install looks great with a great price.
Old Mar 7, 2006 | 04:32 AM
toneeseexb's Avatar
I just installed the exact same one on my box this weekend. It didn't come with instructions so I looked into the tech write up for the YDR short ram intake for guidence in removing the stock air box. After I got the stock air box out, installation was pretty streight forward. I did not have to remove my battery nor my front bumper. The brackets used to harness it to the bolt that holds your battery down and the one that is on the bottom of the battery platform don't exactly fit. The kit comes with these two rubber stops that have 10mm bolts coming out of each end. Once you screw them in and attempt to secure the CAI brackets to them, the bolts rip streight out of the rubber stops so pretty much they only serve as stops instead of a useful way to secure the CAI. No fear though, because the tight fit of the hoses and limited space in the engine compartment keep the thing perfectly snug with no vibration sounds.
I've been driving with it for 3 days now and I definantly notice improved throttle response, extended range in RPM's, and faster top end accelleration. It's a nice enhancement to the Magnaflow exhaust I already have. I highly recommend this bolt on mod to anyone. Sure this CAI is not a brand name, but I think someone would be hard pressed to prove to me that by spending $150.00 more on a brand name CAI that I would see a huge difference in performance. I roll with this one for now and only if I have problems will I install and Injen CAI. I say go for it, you won't be dissappointed.
Old Mar 9, 2006 | 08:24 PM
bBoy's Avatar
dont do it . . ____ quality
Old Mar 9, 2006 | 08:44 PM
toneeseexb's Avatar
Did you have problems with it?
Old Mar 10, 2006 | 09:28 PM
DJRemiasz's Avatar
if you watch videos from aem and injen they have quality filters, and the pipes are percisly cut...the filters in these YDR intakes have no proven tests that they are reliable.
Old Mar 10, 2006 | 10:16 PM
Subcompact Culture's Avatar
The YDR intake has a K&N filter -- doesn't get any more proven than that.
However, the eBay intakes, most of which don't have decent filters, often don't flow as well or filter as well as as K&N.
Old Mar 11, 2006 | 12:38 AM
xknowonex's Avatar
generic intakes a good deals. if u want, u can replace it with a brand name filterdown the road
Old Mar 11, 2006 | 01:29 PM
DJRemiasz's Avatar
yes that is wut i meant sushiboy...the filters dont make too huge of a difference performance wise...i've seen a generic filter vs a k&N and there is better flow in the long run most likely but by a dyno theres no much of a diffrence in whp .25-1hp... but if you get some heat under the hood its good to have a quality filter that can take the heat
Old Mar 12, 2006 | 12:33 AM
itsme's Avatar
havent tried it but have a Injen IS and it works great but this intake looks nice and clean...........
midtowndesi
May 17, 2014 05:06 AM
whitenebula
Jan 2, 2013 02:48 PM
KidJustin
Scion tC 2G Wheel & Tire
Aug 18, 2011 09:14 PM
Lur562
Aug 25, 2010 12:38 PM
peabe
Sep 12, 2005 02:38 AM
