POWER WINDOWS HELP!!
Old Jan 14, 2006 | 02:26 PM
Ninja729's Avatar
Default POWER WINDOWS HELP!!
ok... well i got a problem
on the drivers side the windows work but they dont automatically go down when i push the button down all the way. vice versa with goin uping. then i cant even move the passanger window at the drivers side for some reason. only the passanger can move their own window. so i dont know whats going on ? can any1 help me
Old Jan 14, 2006 | 02:42 PM
WiCkEd_TrInI's Avatar
Go to the dealer. sounds like some wires or sumthing. Gotta love warranty.
Old Jan 14, 2006 | 02:45 PM
Munch's Avatar
Default Re: POWER WINDOWS HELP!!
Easy fix. JUst goto the passenger window. Let it all the way down till it stops. The roll it all the way up till it stops. Then do the same with the driverside window. You will have to open the sunroof all the way till it stops and then close it till it stops. It's in your manual how to reset your windows and suinroof. There is nothing wrong with your wires
Old Jan 14, 2006 | 02:46 PM
SciontCya's Avatar
Big Sky Scion
Not to worry - here comes the obligatory PLEASE SEARCH FIRST slap though...
Roll the windows down all the way.
Now, roll them half-way up.
Now, roll them the whole way up and keep holding the up button for 1-3 secs.
They should now work.
Scott
PS - here's the tC FAQ site: Click Me for FAQ
Old Jan 14, 2006 | 02:50 PM
Ghost_1's Avatar
if you had any stereo speaker work done which requires the removal of the door panel, they might have not fully connected the harness. If you have had no audio work done or anything requiring the removal of the door panel, I suggest you take it to the dealer. Maybe the window master switch is bad or faulty, another posibility could be that the connector could have come loose.
Also I am not sure what you meant by the "windows not going down when the button is pushed all the way down." The auto down only work on the driverside window not on all of them. Only recently have manufactures started making all the windows auto down from the window master switch.
If you just meant the driverside window, it's a problem but if the rest of the windows go down only when pressed this is normal.
shoot sorry bro didn't know it was a TC. . .should read more. . .ha ha ha
Old Jan 14, 2006 | 03:00 PM
SciontCya's Avatar
Big Sky Scion
Wrongo, Ghost!
On the tC, both windows are AUTO up AND down!
Scott
Old Jan 14, 2006 | 03:02 PM
Ninja729's Avatar
ok so when i do it for the passanger window... it will fix it so i can open it and close it on the drivers side?
Old Jan 14, 2006 | 03:07 PM
SciontCya's Avatar
Big Sky Scion
Just get out there and do it.
See for yourself.
Scott
Old Jan 14, 2006 | 03:09 PM
Munch's Avatar
Yes it will.
Old Jan 14, 2006 | 04:19 PM
WeDriveScions's Avatar
Ok...... This is the 1,354,434,343 time this has been asked.... it happens every time you reset your ECU....
follow the instructions for both windows and your sunroof and you'll be good to go....
As for the other answers.... DO NOT go to your dealer for this.
daniinpitt
Apr 4, 2015 08:07 PM
Joeynenj
Nov 25, 2014 05:29 AM
BlueBox
14
Jan 15, 2004 01:08 PM
