i need help with my dream setup! any help is appreciated
Old Jan 27, 2006 | 07:01 PM
bbsukidesu's Avatar
Default i need help with my dream setup! any help is appreciated
ORIGINAL POST:
would it possible to stack these types of wheel spacers?
EDITED POST:
heres what i need help with... i'm planning on getting fender flares that come out around 3" wide. the wheels i am getting are 16x8.5 +25. since they are volks, they dont do any custom offsets like work and ssr. i need help on figuring out how i could get these wheels to be flush with the fender flares. i was thinking of stacking 2 OTG shims AND using 25mm hubcentric spacers. i still dont think that would be enough though.
thanks ahead of time!
Old Jan 27, 2006 | 07:19 PM
magicmanjk808's Avatar
crap aaron, how far out do you need to space?
Old Jan 27, 2006 | 07:23 PM
sexyscionlover's Avatar
contact Mybox he'll do a custom spacer for the size you need so you dont have to space them out by stacking. i would say thats highly unsafe to do, and thast coming from someone with 25 mm studded spacers on their car. contact Sean and see what he can do.
also, what do you need that much spacing for? Widebody or bosozoku styling is all i can imagine!
scott
Old Jan 27, 2006 | 07:38 PM
bbsukidesu's Avatar
hahaha. i'm STILL trying to figure out how i can run 16x8.5 +25 (thats the lowest offset they come in) flush with fender flares that are around 3" wide.
sexyguy...
thanks for the info. i'll definately pm mybox. like i said up there ^ i want to run fender flares but the wheels i want are volks and i was told they dont do any custom offsets.
the ones i want only go to +25 and its an 8.5" wheel.
i think i'll rename this topic....
Old Jan 27, 2006 | 07:41 PM
ctruss's Avatar
I might need flares, where did you get yours?
Old Jan 27, 2006 | 11:19 PM
stankubrick's Avatar
You can only stack the the OTG spacer shims with OTG camber shims. Don't stack 2 OTG spacer shims.
3" past the fenders? You're gonna need about 75mm to be flush. Sounds like a you need a custom spacer. Like Scott said, JDM Palace can probably help you
BTW, which Volk/Rayswheels are you getting? Are they monoblocks? If they are multi-piece, you might wanna double check with MyBoX to see if you can get custom offsets.....
Old Jan 28, 2006 | 12:49 AM
edxa's Avatar
Don't stack, your asking for trouble.
Old Jan 28, 2006 | 04:49 AM
bbsukidesu's Avatar
i didnt get them yet. because . this is just a plan that will take place far down the road.
thanks for the info. they're monoblocks... volk te37 cups .
Old Jan 28, 2006 | 04:58 AM
Sweet! I love those wheels, can't wait to see them on a box!
Old Jan 28, 2006 | 05:00 AM
bBoxed_In's Avatar
16x8.5?? or 16x8??
I was thinking about those wheels but decided against them since I wanted to stick w/ 17's and not down size to 16's.
i wouldn't stack any spacers, PERIOD. definitely would not be a wise thing to do, especially if they aren't hubcentric.
your other option would be to convert to a 5-lug. i think several japanese companies, including Noblesse if i'm not mistaken make a 5-lug conversion that looks like the H&R spacer but converts 4 into 5-lug (again, if i'm not mistaken the Noblesse one is a 20 or a 24mm?). other companies have this kind of conversion for cars like 240's and such. they aren't great for high horsepower but you won't need to worry about that w/ a scion. this option will give you more variety of rims to choose from.
good luck... in the end they'd look sweet.
Old Jan 28, 2006 | 05:07 AM
^^^That's an idea too. I think that fitment is perfect as-is without flares or spacers.
In fact, If it were me, I'd ditch the flares. Then, I might run 10mm spacers w/ -2deg camber in front and 25mm spacers with -3deg camber in the rear. 195/50 tires and a 100mm drop
Old Jan 28, 2006 | 05:08 AM
bbsukidesu's Avatar
Originally Posted by bBoxed_In
16x8.5?? or 16x8??
16x8.5.
if you're the guy with the xb that works at vakamon then i'm the guy that came in asking about those wheels. if not then nevermind. haha.
Old Jan 28, 2006 | 05:11 AM
bbsukidesu's Avatar
i want to be the first!!
Old Jan 28, 2006 | 05:13 AM
bbsukidesu's Avatar
16x8.5?? or 16x8??
i've got my mind set on the cups... i wont settle for anything else. haha. thanks for the info though, i appreciate it.
Old Jan 28, 2006 | 05:56 PM
bbsukidesu's Avatar
heres what mybox said:
Hello Aarron,
I can make you any size spacer you want the widest I have built is 2.5" but I'm sure i can do wider but I need the exact size so I would say get your flares first and then you might find another set of wheels or we should be able to work something out !!
Sean
is there a way of finding out how much inches the wheels will have to go out?
Old Jan 28, 2006 | 06:43 PM
MyBoX's Avatar
I thought they call it Private MSG,
any way, there is no way any one can tell you exactly howmuch you need to space the wheels out, I mean you have no base measurment to start with, so again I would say get one of the two and go from there !! But hey good luck with your dream project !!
Old Jan 29, 2006 | 03:16 AM
bbsukidesu's Avatar
haha my bad. wasnt thinking about that.
Old Jan 30, 2006 | 05:04 AM
tinybigrig's Avatar
i know that you can also get custom adapters from motosport technology in grand terrace ca. they used to make them for us at axis
brent
Old Jan 30, 2006 | 05:24 AM
oBnoXious_XB's Avatar
holy shizz, a 2.5 inch spacer!?
Old Jan 30, 2006 | 08:09 AM
You have to think about what kind of modifications you'll need to do to your fenders. Are you going w/ snap on flares? or going w/ true flares and cutting out your stock fenders? This might dictate what tire diameter you can run and how much stretch you need for clearance.
It seems the best boxes so far with flares have had air suspension, so they don't really need to think of all that. All they needed was to be flush when dumped. They could just ride high, then when they park, just sit the fenders on the tires.
Originally Posted by MyBoX
there is no way any one can tell you exactly how much you need to space the wheels out, I mean you have no base measurment to start with, so again I would say get one of the two and go from there !!
Yeah, I would get the wheels first (the hard part) and see how flush they are to the stock fenders. There could be a lot options just making it ultra flush to the stock fenders with easily available 25mm spacers and camber shims...
LowSchool_Xb2
13
Nov 5, 2016 04:59 AM
mvez
Scion tC 2G Aero & Exterior
Feb 4, 2015 01:15 AM
Beesh
Jan 9, 2015 06:30 PM
