::::: NEW PERRIN FUEL RAIL :::::
Old Feb 3, 2006 | 03:28 PM
clear_bra_guy's Avatar
Default ::::: NEW PERRIN FUEL RAIL :::::
HEY GANG HERES A PICTURE OF THE NEW FUEL RAIL FROM PERRIN JUST SENT IT TO ME LAST NIGHT NO MORE BLUE RAIL FOR THE PHOENIX!!!
old rail
new rail
Old Feb 3, 2006 | 03:39 PM
OEMxB's Avatar
Any noticeable difference in performance? Other than color, whats the change?
Old Feb 3, 2006 | 03:54 PM
Nozerider's Avatar
Please don't post like that.
Old Feb 3, 2006 | 04:02 PM
Serialk1llr's Avatar
OhioScions
^^^ I actually felt the bile building up in the back of my ThRoAt! It hurts enough to see that drek in chatrooms and from little kids posting online, let alone having it here
Old Feb 3, 2006 | 04:42 PM
SO-CAL_TC's Avatar
is there any fuel rails for the tc?
Old Feb 18, 2006 | 09:44 PM
Grimstar's Avatar
ive asked this before and was wondering is there any benefit to having a aftermarket fuel rail when there isn't any aftermarket injectors.....but no answer? How do you like it?
Old Feb 18, 2006 | 10:16 PM
jct's Avatar
jct
its a good up grade when you goto F/I when you have too upgrade your fuel injectors
Old Feb 19, 2006 | 08:00 AM
it also has a port to add nitrous or a fuel gauge
Old Feb 19, 2006 | 11:24 PM
itsme's Avatar
whats the effects of the fuel rail on a stock xb an/or xb with I/H/E
Old Feb 19, 2006 | 11:27 PM
itsme's Avatar
what kinda spark plug wires are you runnin? they look tight. how do they hook up?
Old Feb 20, 2006 | 12:33 AM
nology wires
Old Feb 20, 2006 | 02:44 AM
spawnconnery's Avatar
Im still not sure why the new fuel rail. Any reason to get it if your not going to go f/i or add nitrous or a fuel guage? Any change in performance? Did the nology wires make any difference or are they just cosmetic?
Old Feb 20, 2006 | 03:21 AM
the fuel rail is a mod, if you plan to upgrade any of the fuel system this is a good starting point. if your not then it probably is not necessary for you.
as for the wires, direct from the manufacturers site:
Nology HotWires are the most technologically advanced ignition wires available. HotWires create the most powerful spark possible. HotWires are engineered with a special built-in capacitor, exclusive only to HotWires. This revolutionary design allows energy from the ignition coil to accumulate in the capacitor until the voltage at the spark plug electrodes reaches the ionization point. At that split second point the entire power of the stored spark is discharged at once, creating a spark 300 times more powerful. The result is faster, more complete combustion, and most importantly,
MORE HORSEPOWER that's 100%. Smog Legal.
Old Feb 20, 2006 | 04:21 AM
itsme's Avatar
how did you run the nology wires?
Old Feb 20, 2006 | 04:31 AM
look at the pix above, its from plug to coil pak no problem
Old Feb 20, 2006 | 12:17 PM
DJ_SpaRky's Avatar
they look pointless, because it's actually adding wires between the coilpack & the plugs, that used to be directly connected.
Old Feb 20, 2006 | 04:11 PM
readf my last post
Old Feb 20, 2006 | 05:07 PM
itsme's Avatar
whats the bracket? did it come with the wires?
steeze69
May 24, 2021 02:57 AM
mudguy
Oct 22, 2015 04:31 PM
MeDizzy
Oct 8, 2015 03:31 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
paisatronix
Sep 5, 2015 04:13 AM
