s tech= new struts?
Old Feb 7, 2006 | 06:15 PM
vvti24's Avatar
Default s tech= new struts?
I plan on gettin the tein s tech springs... I live in central New Jersey which many many pots holes and bumps... If i do get the springs do what are my consequences of keeping the STOCK STRUTS? Does that put more WEAR on the new springs? How long would my oem struts LAST?
Old Feb 7, 2006 | 06:16 PM
vvti24's Avatar
also any pics of pplz who have the s tech springs on a black tc? what struts is prefered with the s tech springs?
Old Feb 7, 2006 | 06:18 PM
ack154's Avatar
More wear on the new springs? Not likely.
Consequences? Well... your oem struts will just wear out a bit faster than they normally would. Though I know that many people have been lowered and are running fine on stock struts for 10k, 15k, likely even 20k+.
I think it should be in the back of your mind to replace them, but not anything you MUST do right now.
But ya, how long they last is really a toss up. Now IF they happen to blow out and you don't replace them ASAP, then they could start to ruin your springs because the springs would now be doing all of the work.
Old Feb 7, 2006 | 06:20 PM
ack154's Avatar
There are a lot of pics here:
https://www.scionlife.com/forums/viewtopic.php?t=39485
Likely anyone with stechs should have posted in there by now - or should anyways.
The only aftermarket struts available so far are from TRD or Koni... but if you're going to consider buying springs and new struts... you should really just drop in a nother $200 or so and get coilovers.
Old Feb 7, 2006 | 06:23 PM
eujin's Avatar
You'd end up having to replace your stock shocks later down the road..
In that time I'd say save and get a coilover setup down the road like Tein, Tanabe, or H&R simply because they are true coilovers that replaces spring and shock. It will save time and money in the long run.
yupinmytC
22
Jul 27, 2024 07:08 PM
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
kb1sxv
Oct 21, 2015 05:00 PM
babyfac3pn01
Oct 19, 2015 07:24 AM
Sgtfluffy16
Sep 30, 2015 01:42 PM
