Inverted Subs
Old Feb 8, 2006 | 01:48 PM
TheIcon's Avatar
Default Inverted Subs
Can people give me the pros and cons of inverting there subs?
Old Feb 8, 2006 | 04:10 PM
TXboxdriver's Avatar
NONE OF EITHER
there is no difference as to which way it faces
it works the same, sounds the same
guess it might matter how pretty your basket/magnet is?
Old Feb 8, 2006 | 06:00 PM
mfenske's Avatar
Originally Posted by TXboxdriver
NONE OF EITHER
TX pretty much nailed it. In most applications I would say it's purely cosmetic. You might (and it's a pretty slim MIGHT) gain like .1 db in a ported application. Mark
Old Feb 8, 2006 | 06:25 PM
trebor's Avatar
If your running alot of power the motor might run cooler being on the outside of the box, therefore more efficient.
Old Feb 8, 2006 | 07:26 PM
jbae1221's Avatar
^^ true.. heat is a main concern.. like if you have 4 huge subs pushing like 1000watts each you know... then inverting will make a difference in the heat dissipation.
Old Feb 8, 2006 | 07:52 PM
^^ valid...never thought of that
my Earthquake 10" has a HUGE magnet and that's why mine is inverted...more intimidating that way heh heh
Old Feb 8, 2006 | 09:05 PM
mfenske's Avatar
What a dolt I am! If you are mounting inverted you way want to experiment with the phasing of the driver since it will be out of phase with the rest of the system. On the older (maybe newer too?) Eclipse decks I know you could alter the phasing of the sub right from the deck. Mark
Old Feb 8, 2006 | 09:24 PM
it is even easier with it inverted
the wires are right there....just switch them!!
Old Feb 8, 2006 | 09:43 PM
mfenske's Avatar
I'd just switch them at the amp because invariably you'll get someone that says "Your sub's hooked up backwards". Mark
Old Feb 9, 2006 | 01:41 PM
SCI_TC_GUY's Avatar
^^ haha... +1.... that's something else I like about my kenwood.... phase control...
Old Feb 9, 2006 | 04:09 PM
Prototype_xB's Avatar
most decent HU's today have normal and inverted phase control
BlingSlade
Oct 19, 2016 12:39 AM
crimson10tC
Sep 10, 2015 08:44 PM
umnitza
Sep 1, 2015 08:06 PM
javio24
Aug 23, 2015 01:07 AM
sethmskinner
Aug 4, 2015 02:38 AM
