Problems with HU. Anyone else???
Old Feb 9, 2006 | 05:37 PM
superstick58's Avatar
Default Problems with HU. Anyone else???
I've had a few issues with my stock head unit and am wondering if this is a common thing. If not, I will likely try to get a replacement under warranty. There's only a couple problems, but they are pretty annoying.
First, occasionaly when I play MP3's, the system will play only the beginning of the song. It will arbitrarily skip to the next song. This doesn't happen every time, but often enough.
Also, I have issues with the tuner. The unit will drop its current frequency. I will tune down or up by 0.2 MHz(or kHz or whatever radio is broadcast at) all by itself. Again, this doesn't happen under any specific circumstances, but happens often enough to be a problem.
These are seemingly minor flaws, but they happen often enough to not be random occurrences. Has anyone else experienced these same events? Is a replacement a possibility from warrenty? It would be difficult to reproduce the problems to a technician because of the seemingly random occurrence of the problems.
Old Feb 9, 2006 | 05:46 PM
ack154's Avatar
Do you have a 2006 tC? Are you possibly hitting any of the steering wheel controls and just not noticing?
You could easily be pressing the skip button to skip to the next MP3. Or even on the radio, it may also be tuning from the steering wheel controls - though I don't have a 2006 and not sure if the radio does that.
Old Feb 9, 2006 | 05:50 PM
I do have a 2006. Yes I am aware of the steering weel controls. However, that is simply not the case. First, when the tune button is pressed the tuner goes to the next preset, not the next frequency.
I cannot use the same argument for the CD playback except that I have not noticed it with CD's. I've only noticed it happen with MP3's, and that it has occurred multiple times with mp3's and I actually listen to CD's more often and have not seen the problem.
Old Feb 22, 2006 | 09:25 PM
I guess I'm the only one. Hopefully I can get a replacement then. Any recommendations?
Old Feb 23, 2006 | 04:45 AM
JOEinSD's Avatar
you aren't the only one...
https://www.scionlife.com/forums/vie...764&highlight=
Old Feb 24, 2006 | 04:28 AM
OneLiterPeter's Avatar
I don't think the problem is the head unit.
Mp3 CD's need to be finalized (closed). Open or multi-session CD's will do really screwy things when played in most HU's.
Make a duplicate CD that's closed and give it a try.
Old Feb 24, 2006 | 05:16 AM
Nick06tC's Avatar
You arent the only one. I have heard of others. I have a problem of I will adjust the volume with the **** and it will skip a track instead. So instead I use the steering wheel to adjust volume.
Old Feb 24, 2006 | 07:27 PM
monkeyMojo's Avatar
You are not alone, and now I don't feel like I'm going nuts. My 06 HU does both of those.. Very randomly it will change the radio frequency (just barely) and even rarer an MP3 will play partically and then skip to the next file.
RY_TC07
Jul 18, 2017 05:18 PM
bravosixniner
May 24, 2015 09:56 AM
ScionXa06
May 18, 2015 10:05 PM
claiknx
May 17, 2015 11:44 PM
crocker
Dec 2, 2014 03:44 AM
