Suspension Guru's I have a question?
Old Feb 16, 2006 | 01:25 PM
06_JDM_Tc's Avatar
MN Scions
Default Suspension Guru's I have a question?
I recently installed my Tein S tech springs. Now when ever i hit a crack or a little bump in the road, my suspension makes clanking noise like the top 3 bolts are loose and the strut asem. is boucing? I have checked and tightened all bolts again on all the suspension, they are all tight, none are loose. Has anyone had this problem if so what can i do or what should be my next step.
Thanks guys.
Old Feb 16, 2006 | 01:31 PM
ack154's Avatar
I don't think I'm really a guru or anything, but...
When you mounted the springs into the struts, were you sure that the springs lined up correctly with the strut seat? They have to be set in there a specific way and if they're not lined up right, you might get that clanking sound.
Old Feb 16, 2006 | 01:45 PM
06_JDM_Tc's Avatar
MN Scions
I am almost postive that they were set in right..
Old Feb 16, 2006 | 09:45 PM
06_JDM_Tc's Avatar
MN Scions
Does anyone know if at the top of the strut there are 2 flat spots cut into it and the cap assembly also has 2 flat spots so they line up. If its like the xa and xb i think i found my problem? any help would be great
thanks
Old Feb 17, 2006 | 01:45 PM
06_JDM_Tc's Avatar
MN Scions
nobody? man this forum is slow for how many members it has..
Old Feb 17, 2006 | 02:16 PM
ScionBandit's Avatar
sIcKsCiOnS
DelMarVa
Scion Tuners
Default Re: Suspension Guru's I have a question?
Thanks guys.
had same issue when i had mine...had my toyota tech install them, didn't mount it right....annoying as h***
might want to take them out and re mount it all, best bet
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
