How to: Remove the entire dash...?
Old Feb 16, 2006 | 10:45 PM
SmokingTires's Avatar
Default How to: Remove the entire dash...?
I'm trying to get the entire dash off but I am a little confused as to how? Any insight would be much appreciated!!! Thanks
Old Feb 17, 2006 | 12:08 AM
Tay831's Avatar
Hehe alot of people ask this question the best option is to try and search fo it first. If you use quote marks you can narro your search. Besides the point the way to get it off is pull of ac ***** unscrew screws and make shurrrrrrrre the cubby is closed and the pull from the top down I usually hold on to the air vents and pull! Dont be afraid to give some force if you follow those instructions you should be fine.
Old Feb 17, 2006 | 12:28 AM
I searched several times, "how to remove the dash" "dash removal" "remove the dash" etc. I did not find one topic that has said how to remove the entire dash. I have taken the center dash off several times no problem. I want the ENTIRE dash off. Thanks though.
Old Feb 17, 2006 | 01:00 AM
ElChupacabra's Avatar
If you want the top half of the dash off let me know. I can direct you. Ive done it before several times...
I dont know how to get the lower part of the dash off. Never tackled that one....
Old Feb 17, 2006 | 02:02 AM
Spider13's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=23214
This is for a NAv install. But it shows you how step by step.
Old Feb 17, 2006 | 08:47 AM
Ok so someone made a write up and I find it 4 hours after I've given up. I got stuck with the last bolt under the passenger airbag. DUH. Oh well I got my L.E.D. lights in the dash so I'm happy... Thanks guys for the help
Old Feb 17, 2006 | 01:36 PM
Yeah that was the bolt that had me hung up for a while. I know its too late now but you just pop out the square in the dash above the glove box and you have access to the last bolt....
Old Feb 17, 2006 | 01:56 PM
chadfo's Avatar
For anyone else doing searches on this topic:
https://www.scionlife.com/forums/vie...647&highlight=
brett561tc
Sep 15, 2015 06:33 AM
mc1114
Scion tC 1G Aero & Exterior
Aug 10, 2015 10:34 AM
wejarrell
10
Aug 5, 2015 09:19 PM
Scionxa180
Jul 25, 2015 05:22 AM
excessads
Jul 13, 2015 11:41 AM
