How to: Remove the entire dash...?
Hehe alot of people ask this question the best option is to try and search fo it first. If you use quote marks you can narro your search. Besides the point the way to get it off is pull of ac ***** unscrew screws and make shurrrrrrrre the cubby is closed and the pull from the top down I usually hold on to the air vents and pull! Dont be afraid to give some force if you follow those instructions you should be fine.
I searched several times, "how to remove the dash" "dash removal" "remove the dash" etc. I did not find one topic that has said how to remove the entire dash. I have taken the center dash off several times no problem. I want the ENTIRE dash off. Thanks though.
https://www.scionlife.com/forums/viewtopic.php?t=23214
This is for a NAv install. But it shows you how step by step.
Ok so someone made a write up and I find it 4 hours after I've given up. I got stuck with the last bolt under the passenger airbag. DUH. Oh well I got my L.E.D. lights in the dash so I'm happy... Thanks guys for the help
Scionxa180
07-25-2015 05:22 AM
