ne1 with bb/jdm fogs ,help!
All you really need are the pictures. Just hold the pic up close to your fuse box and you should be able to find it. I remember mine was a _____ and the socket for the relay was clipped onto the side of the main fuse box. I tried to unclip it thinking it would be easier but I ended up only getting it halfway off and then it was even more of a _____ to get that relay on. Just wrestle with it and if you get annoyed grab a beer and give it a rest then go at it again.
If you travel to the tech section the pics from the overboost guys should be enough to show you where that thing attaches to the side. Also while you're there if you are looking to use that switch you can checkout the writeup I did.
Originally Posted by bBlover
Umm where did you get em?? I want some. Oh and does it come with a switch like the OEM fogs??
It comes with a switch for a bB. If you're good with a soldering iron, you can use it. Otherwise you'll have to pick up an xB switch from Toyota.
OpTicaL
Sep 16, 2015 10:25 AM
umnitza
Sep 1, 2015 08:06 PM
