Location of Power Window Fuse?
Old Feb 24, 2006 | 10:05 PM
D1G1T4L's Avatar
Default Location of Power Window Fuse?
My passenger-side window isn't working. The little light on the switch isn't even on. I thought I would check to see if it was due to a blown fuse. But I can't figure out which one/s it is. None of the markings on the fuse box lid by the battery look like they are for windows. My buddy pulled all of the small fuses there and they all looked OK. Is there also another fuse box in the cabin somewhere? Anyone know where the power window fuses are?
Thanks
_Bill
___
Old Feb 25, 2006 | 02:10 AM
tweetertc's Avatar
drivers side under dash... left hand side stick your head under and you should see it..
Old Mar 10, 2006 | 10:33 PM
krazie1's Avatar
yeah mine just went out 2 days ago
freakin passenger window don't work and the light flashes, weird anyone else having this issue???
Old Mar 11, 2006 | 11:57 AM
SCI_TC_GUY's Avatar
I'm guessing anyone with this problem has disconnected a battery terminal recently... roll the window all the way up and continue holding the switch in the up position for about 3 seconds.... do this with all 3 switches and it should work again...
Old Mar 11, 2006 | 07:27 PM
krazie1's Avatar
tried it and nothing and no I didn't disconnect the battery ever!! but might when the force induction of my choice goes in
Old Mar 12, 2006 | 04:09 PM
D1G1T4L's Avatar
OK, I'm dumb.
At some point I must have hit the little button on the door that turns off the passenger window. I didn't even know it was there. It's actually kind of stupid that it turns off the control on my side too... What's the point of that?
But, at least I found the interior fuse box. Earlier I had opened up the panel above the hood release and thought that was it. But after looking more closely in the manual I found that the fuse box is actually below/behind the hood release. So I checked the right door fuse and it was fine. Then I started wondering if there was some child-safety switch somewhere. And there was.
So I'm dumb. But I'm just happy that the problem was me being stupid instead of something that would cost a bunch of money.
Old Oct 15, 2015 | 08:10 PM
tcountry627's Avatar
I know where the fuses are.....which fuse is the one that works the power windows? Only my drivers side window won't go back up. What's the fuse labeled? Thanks...
gturbo
Oct 23, 2010 06:34 PM
flying_toaster
11
May 2, 2008 01:41 PM
twinturboed
10
Apr 19, 2008 02:15 AM
xjamiex
Scion tC 1G ICE & Interior
Mar 14, 2008 08:36 AM
twinturboed
Feb 1, 2008 03:30 AM
