Green Audio Wire - 4ga
Old Mar 5, 2006 | 05:02 PM
NVmyBox's Avatar
Default Green Audio Wire - 4ga
Does anyone know where I can find green 4 gauge amp wire? I'm hoping to find some clear candy green wire to power our subs. I tried googling to no avail...
Old Mar 5, 2006 | 11:17 PM
ProshopXB's Avatar
Wouldnt look as good as what yourf looking for, but maybe spray painting the wire would work, how much of the wire are you really gonna see any way, just an idea.
Old Mar 5, 2006 | 11:25 PM
chadfo's Avatar
I've never seen or heard of green. You can get flex loom in green to cover it.
Old Mar 6, 2006 | 12:07 AM
frogbox's Avatar
Saw some on e-bay.
Check out some of the online stores at e.bay.
Where i got mine.
Old Mar 6, 2006 | 12:04 PM
NVmyBox's Avatar
^^^ Is your wire clear green or solid? The only thing I've been able to find is solid green.... If it's clear can you tell me what to search for, or maybe a link plz...
Thanks for all the input guys!!!
Old Mar 6, 2006 | 02:58 PM
trdsparks's Avatar
I would buy some good wire and cover it with something. You audio system is only as strong as it's weakest link. You don't want to skimp on you power or ground wires. Trust me it's a lot easier to cover a wire that to have to deal with bad sound.
Old Mar 6, 2006 | 03:17 PM
mfenske's Avatar
http://www.weldingsupply.com Go under "cable welding" and they've got various colors and gauges.
They've got green, and it's cheap too. Mark
Old Mar 6, 2006 | 04:29 PM
archangel's Avatar
What cable end do you recommend from that welding page to make a grounding kit, seems like you need special tools to use the crimp on , I would worry that the screw on ones would not have as good of a connection
Old Mar 6, 2006 | 06:26 PM
mfenske's Avatar
Cablewise I'd recommend the biggest (lowest gauge) your budget allows. Personally I have some 1/0 that I plan on using. I'd recommend the standard crimp-on lugs but I would take it a couple steps further. First, after crimping on the connector (plus a standard bench vise with a bolt at the seam of the connector works GREAT!) I would take a propane torch and heat the joint and put some 60/40 Rosin core solder in there so that it's shiny and well covered. Second, then I'd take some shrink wrap and use the torch again (NOT DIRECTLY) to heat the shrink wrap and be happy with a secure electrical connection. Mark
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
streetracerr
Jul 11, 2015 09:52 PM
dltjdgns66
Scion tC 1G ICE & Interior
Apr 15, 2015 07:59 AM
NewBox06
Feb 3, 2015 12:36 PM
bryanrx7
Jan 1, 2004 09:53 PM
