What are better speakers Eclipse or MB Quart?
Old Mar 8, 2006 | 11:36 PM
Shorty's Avatar
Default What are better speakers Eclipse or MB Quart?
OK peoples I Need Help I Have my money ready to be spent in my audio.... Thing is I have to choose between two brands. Either Eclipse components and ***. speakers for my tc OR Go with MB Quart Components and *** speakers? Just cant decide which would be a better choice or speakers!!! PLEASE help! The following are choses:
By the way what size are the Front and Rear i've heard they are all 6.5? just to make Sure?
ECLIPSE
SC8264 6.5 components 2way RMS 85 MAX 250 Front speakers
SC8254 5.25 components 2way RMS 75 MAX 220 Front speakers IF its the size!!
SP8962 6.5 *** 2way RMS 50 MAX 100 Rear
SP8952 5.25 *** 2way RMS 40 MAX 80 Rear if these are the Size!!
MB QUART
Reference Same end as the eclipse
RVF216 6.5 Components 2way RMS 70-140 Front speakers
RVF213 5.25 components 2way RMS 50-110 Front in these are the size!!
RUA216 6.5 *** 2way RMS 50-120 Rear
RUA213 5.25 *** 2way RMS 30-90 rear if it the size
Discus Lower end of MB Quart
DSF216 6.5 components 2way RMS 50-120
DSF213 5.25 components 2way RMS 35-90
DKF113 5.25 *** 2way RMS 35-90
DKF116 6.5 *** 2way RMS 35-90
Old Mar 8, 2006 | 11:47 PM
shepardtc's Avatar
any kicker ..... all the way mb are better on lower levels highs kicker!!! what kind of db do you want?
Old Mar 8, 2006 | 11:50 PM
shepardtc's Avatar
all the way kicker
Old Mar 9, 2006 | 12:16 AM
shepardtc's Avatar
trust me !! i have used them all kicker will last!!
Old Mar 9, 2006 | 12:20 AM
Shorty's Avatar
Both of the are at the level i want. Also i will be running a 12'' eclipse sub either one that runs at RMS 500 MAX 1500 or a 12'' running at RMS 450 MAX 900 with a eclipse amp for subs and 4ch amp for speakers RMS 75x4 at 4ohms
Old Mar 9, 2006 | 12:29 AM
shepardtc's Avatar
kicker amp 2 oms rather if you get 1.8 or 1.5 oms the better. you people have no idea........... the lower the oms the lower the db is. means more power. .1.2 is the best. its hard to get there but it can be reached. example : if you are running 2 subs 15'' at 8 oms vs 2 8 '' subs at 2 ohms the 8 '' will pound hader...
Old Mar 9, 2006 | 12:35 AM
shepardtc's Avatar
anything lower you cant hear .. just might feel!!!
Old Mar 9, 2006 | 12:36 AM
shepardtc's Avatar
ty
Old Mar 9, 2006 | 12:39 AM
shepardtc's Avatar
do kicker, they will take the abuse
Old Mar 9, 2006 | 12:44 AM
shepardtc's Avatar
do it !!!!! dont be stupid
trust me!!!
Old Mar 9, 2006 | 01:33 AM
Merc_tc's Avatar
that is not exactly true. the lower the ohms does not mean the db will be high. It just means you get more stable power from your amp if you match it right. ( subs ohms need to match the ohms of the amp. ie. 1 ohms sub + a 1 ohms amp = more stable power with less distortion.
What eclipse subs do you want?
Old Mar 9, 2006 | 01:50 AM
shepardtc's Avatar
MERC YOU ARE HI oms burned are oms learned .... trust me!! you are wrong!!
get a sub that is rather subs that are 6 om like mbq reduce it to 2 oms stable you will produce 1.8 oms
= thump ..... 6 oms wo stable will = nothing.... you want thump you need 4 oms vs the power of your amp .
do this ... if you got 2 subs go under 80 or 80 plus a few. gain 75% that is it...
Old Mar 9, 2006 | 02:00 AM
shepardtc's Avatar
get kicker you will be happy
Old Mar 9, 2006 | 02:11 AM
mike_szam's Avatar
id go with mb quarts over kicker, kicker makes good subs but as for interior i wouldnt i have eclipse and they are loud but im switching to mmats but anyways i would go with the mb's but thats just me
Old Mar 9, 2006 | 03:24 AM
Shorty's Avatar
well kicker is alright i might start looking more into kicker but i've heard mix reviews on it....
Was thinking of a 12'' sub eclipse to be exact is either the SW7124 DVC-T4 or the new SW7200 12'' sub
Old Mar 9, 2006 | 03:37 AM
TcDepo's Avatar
MB QUARTS ARE QUALITY SPEAKERS WithOut a question...
Old Mar 9, 2006 | 03:43 AM
Merc_tc's Avatar
What the Heck are you talking about!
if you are running two subs that are 2 Ohms dvc it will be 2 not 1.8. A single 2ohm dvc will be 1.0 ohm in parallel or 4 ohms and 2 ohms in series. Plus you can't reduce a 6ohm to a 2 ohm, you can only go to 3 ohms. If you want to thump the you need to match the ohms of your amp to the ohms of your subs.
Im a second generation installer i know
Old Mar 9, 2006 | 03:49 AM
Merc_tc's Avatar
if you are not getting the L7 kicker sub then get the eclipse. I've had both. MB Quart Components and *** speakers and better then Kicker and Eclipse components. MB Quart are cleaner.
Old Mar 9, 2006 | 04:00 AM
Shorty's Avatar
Thanks Guys...for the info its this information is being pretty helpful. Well now im leaning more over MB Quart than eclipse but which MB Quart components should i go with??
And Another Thing with size Speakers are in the Front and The Rear???
Old Mar 9, 2006 | 04:01 AM
shepardtc's Avatar
2 gen? im a 1st gen and if you go with 8 oh if you have the right amp it will kick it down to 1.890 rather 1.670 om with the right set up ...... i worked for the best of the best.
please dont tell me whats the best
