What are better speakers Eclipse or MB Quart?
Old Mar 17, 2006 | 03:11 AM
  #41
Shorty's Avatar
Guys Need INFO on wiring? When running wire from your batterys to your amps do you's send both + and - OR just the + and connect your - negative from you chassis? I bought A amp kit and only included a short piece that connects to the chassis ground which also shows ONLY the + positive wire running to the amps and have the - negative to your chassis?
Old Mar 17, 2006 | 06:48 AM
  #42
mowmow's Avatar
I defintely go with MB Quarts especially Premium series
I use
MB Quarts premium PCE216 6.5"for front ($259 brand new from ebay )
MB Quarts premium PCE213 5 1/4' for rear($250 rand new from ebay )
on a 4 channel Eclipse amp and AVN 2454
It's so clean and accurate you won't believe it.
Ebay is your friend if you do your research.
Old Mar 17, 2006 | 11:11 AM
  #43
SCI_TC_GUY's Avatar
Yes, run + from battery with a fuse within 18" of battery, and ground with the same gauge wire to the chassis.... the ground should be less than 3 ft.
Old Mar 17, 2006 | 11:19 AM
  #44
Shorty's Avatar
Nice Thanks man i was wondering of the wiring because seen couple diagrams different got me confused for a min and need quick info going to start my audio today after work installing everything! and had ran only a + to the amp.....so i guess it was right and i remeber now it was only 3ft long the - neg. from the amp to the chassis! Thanks again
yupinmytC
22
Jul 27, 2024 07:08 PM
mudguy
Oct 22, 2015 04:31 PM
kslim619
Aug 18, 2015 01:22 PM
carid
Aug 7, 2015 11:32 AM
